I have been trying to modify the ICE program-launching source code to allow it to execute another program after the execution of the one it called is complete. The only problem is I am really bad overall at ASM. It launches the program correctly, but when the program it launched completes I get the following error
I'm not sure what I'm doing wrong, because, again, I still don't completely understand ASM.
Here is the source code (and I apologize for my badly-formatted, probably redundant code):
NMI reset caused by writing to the stack limit at address 0xd19881. Hint: Probably a stack overflow (aka too much recursion).
public _RunPrgm
extern __exitsp
_RunPrgm:
call 0021A3Ch ; _DrawStatusBar
ld de, 0D09466h ; plotSScreen
ld hl, StartRunProgram
ld bc, EndRunProgram - StartRunProgram
ldir
jp 0D09466h ; plotSScreen
StartRunProgram:
; Copy the name to OP1
pop hl
pop hl ; HL points to the program name
ld de, 0D005F9h ; OP1 + 1
push de
ld bc, 8
ldir
pop hl
dec hl
ld (hl), 5 ; ProgObj
; Cleanup C things
ld sp, (__exitsp + 1);
pop iy
pop af
ex (sp), hl
ld (hl), a
call 00004F0h ; usb_ResetTimers
pop hl
; Remove CESH from UserMem
ld hl, 0D1A881h ; userMem
ld de, (0D0118Ch) ; asm_prgm_size
call 0020590h ; _DelMem
; Copy the new program to UserMem and jump to it
call 002050Ch ; _ChkFindSym
ex de, hl
call 0021D9Ch ; _LoadDEInd_s
inc hl
inc hl
push hl
push de
ex de, hl
call 002072Ch ; _ErrNotEnoughMem
pop hl
ld (0D0118Ch), hl ; asm_prgm_size
ld de, 0D1A881h ; userMem
push de
call 0020514h ; _InsertMem
pop de
pop hl
ld bc, (0D0118Ch) ; asm_prgm_size
add hl, bc
ldir
ld hl, RunShell
ld bc, EndRunShell - RunShell
ldir
; And finally run the program!
jp 0D1A881h ; userMem
EndRunProgram:
RunShell:
ld hl, StartRunShell
ld bc, EndRunShell - StartRunShell
ldir
ld hl, de
dec hl
dec hl
dec hl
dec hl
dec hl
StartRunShell:
push de
ld bc, 8
ldir
pop hl
dec hl
; Remove current program from UserMem
; Copy the shell to UserMem and jump to it
ex de, hl
inc hl
inc hl
push hl
push de
ex de, hl
pop hl
push de
pop de
pop hl
add hl, bc
ldir
; And finally run the shell!
db "CESH",0,0,0,0
EndRunShell:
