My code:
from tkinter import *
from googlesearch import search
def search_input():
    global e
    global j
    search1 = e.get()
    try:
    except ImportError:
        print("No module named google")
    for j in search(search1, tld="co.in", num=10, stop=10, pause=2):
        results()
def results():
    results1 = Label(text = j)
    results1.pack()
main_screen = Tk()
main_screen.geometry("700x250")
main_screen.title("Inphorium")
e = Entry(main_screen, width=40, borderwidth=5)
e.grid(row=3, column=4, columnspan=3, padx=10, pady=10)
submit = Button(main_screen, text = "Search", width = 5, command = search_input)
submit.grid(row=3, column = 8)
spacer = Label(main_screen, text = "                 ")
spacer.grid(row = 3, column = 0)
spacer.grid(row = 3, column = 1)
spacer.grid(row = 3, column = 2)
spacer.grid(row = 3, column = 3)
spacer.grid(row=0,column=0)
spacer.grid(row=1,column=0)
I am trying to make a google interpreter but this error shows up:
>>> Exception in Tkinter callback
Traceback (most recent call last):
File "C:\Users\warth\AppData\Local\Programs\Python\Python39\lib\tkinter\__init__.py", line 1885, in __call__
return self.func(*args)
File "C:\Users\warth\AppData\Local\Programs\Python\Python39\Emphorium_main.py", line 13, in search_input
results()
File "C:\Users\warth\AppData\Local\Programs\Python\Python39\Emphorium_main.py", line 17, in results
results1.pack()
File "C:\Users\warth\AppData\Local\Programs\Python\Python39\lib\tkinter\__init__.py", line 2389, in pack_configure
self.tk.call(
_tkinter.TclError: cannot use geometry manager pack inside . which already has slaves managed by grid
I'm unfamiliar with tk, but the error seems clear enough to me. You're using grid layout for most of the window, and it tells you that it's not permitted to mix grid and pack layout methods.
