Izder456 wrote:
MateoConLechuga wrote:
Wtf is int tab[] = {};
Isn't that how do it?
Hell no.
Izder456 wrote:
edit :
I changed the int declaration from this :
int z;
int f;
int a;
int x;
int i;
to this :
uint16_t z;
uint32_t f;
uint32_t a;
uint32_t x;
uint32_t i;
but...the problem still persists
What the hell, why did you change it to these types? They are the most inefficient and large ones you could choose. I swear you are just trolling us at this point.
Hell no.
ok then how'd I do it?
I thought an unsigned long and unsigned int would work
would long uint8_t && uint8_t work too?
EDIT : I got dave's code working in C traslated from lua.
Here's it :
// { prgmSEIVEC2 } { v1 }
// Author: izder456
// License: n/a
// Description: generate primes, but faster!
/* Keep these headers */
#include <stdbool.h>
#include <stddef.h>
#include <stdint.h>
#include <tice.h>
/* Standard headers */
#include <math.h>
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
/* Other available headers: stdarg.h, setjmp.h, assert.h, ctype.h, float.h, iso646.h, limits.h, errno.h */
/* uint8_t is an unsigned integer that can range from 0-255. */
/* It performs faster than just an int, so try to use it (or int8_t) when possible */
/* Put all your code here */
void main(void)
    int tab[10000];
    uint32_t p = 0;
    float q;
    uint16_t z;
    uint8_t f;
    uint16_t a;
    uint16_t x;
    uint32_t i;
    char zstr[2];
    char * ptr;
    char ques[7] = "Till? ";
    char input[] = "";
    os_ClrHomeFull();
    os_GetStringInput(ques, input, 10);
    i = strtol(input, & ptr, 0);
    for(z=2;z<=i;z++) {
        q=sqrt(z);
        f=0;
        for(x=1;x<=p;x++) {
            a=tab[x];
            if(a>q) {
                break;
            if((z%a)==0) {
                f=1;
                break;
        if(f==0) {
            p++;
            tab[p]=z;
            sprintf(zstr, "%d", z);
            os_NewLine();
            os_PutStrFull(zstr);
    while(!os_GetCSC());
It is significantly faster that the other version, thanks dave! I did have to statically declare the tab[] array. so it has a max of 10000, but could that go any higher?
EDIT2 : There was a bug that generated numbers that are not prime so i attempted to fix that. it's now fixed
// { prgmSEIVEC2 } { v1.1 }
// Author: izder456
// License: n/a
#include <stddef.h>
#include <stdint.h>
#include <tice.h>
#include <math.h>
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
void print(int z); // I added this to not have something compiled twice.
void main(void)
    uint16_t tab[10000];
    uint16_t p = 0;
    float q;
    uint16_t z;
    uint8_t f;
    uint16_t a;
    uint16_t x;
    uint16_t i;
    char * ptr;
    char input[] = "";
    os_ClrHomeFull();
    for(z=2;z<=i;z++) {
        q=sqrt(z);
        f=0;
        for(x=1;x<=p;x++) {
            a=tab[x];
            if(a>q) {
                break;
            if((z%a)==0) {
                f=1;
                break;
        if(f==0) {
            /*this is the hot fix code, it checks if the number is odd,
            else it's two it'll still print, which should cover all primes*/
            if(z%2!=0) {
                p++
                tab[p]=z;
                print(z);
            else if(z==2) {
                p++
                tab[p]=z;
                print(z);
            else;
        if (os_GetCSC()) {
            os_NewLine();
            os_PutStrFull("Interrupt detected");
            break;
void print(int z) {
    char zstr[2];
    os_NewLine();
int tab[10000];
DrDnar wrote:
Oh, no no no, don't run that.
While you could statically allocate the array:
int tab[1000];
doing so would be unwise. Stack space on the CE is limited, and due to limitations in Zilog's C compiler, functions suddenly get much slower if they have more than 128 bytes of local variables.
I mean, how come you don't read.
Also, 16 bit and 32 bit integers are going to be slow and large because the processor works natively on 24 bit and 8 bit integers. So use those sizes instead.
I did read, and I did attempt to use dynamic memory allocation, but just gave up Razz
ok, i'll try that.
EDIT :
Here's the code with 24bit and 8bit integers. Also, is has a static array, and the input strings are statically allocated as well
// { prgmSEIVEC2 } { v1.1.1 }
// Author: izder456
// License: n/a
#include <stddef.h>
#include <stdint.h>
#include <tice.h>
#include <math.h>
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
void print(uint24_t z);
void main(void)
    static uint24_t tab[10000];
    uint24_t p = 0;
    float q;
    uint24_t z;
    uint8_t f;
    uint24_t a;
    uint24_t x;
    uint24_t i;
    char * ptr;
    char input[10];
    os_ClrHomeFull();
    os_GetStringInput(ques, input, sizeof(input));
    for(z=2;z<=i;z++) {
        q=sqrt(z);
        f=0;
        for(x=1;x<=p;x++) {
            a=tab[x];
            if(a>q) {
                break;
            if((z%a)==0) {
                f=1;
                break;
        if(f==0) {
            if(z%2!=0) {
                p++;
                tab[p]=z;
                print(z);
            else if(z==2) {
                p++;
                tab[p]=z;
                print(z);
            else;
        if (os_GetCSC()) {
            os_NewLine();
            break;
    os_NewLine();
    os_PutStrFull("Done!");
void print(uint24_t z) {
    char zstr[10];
    sprintf(zstr, "%u", z);
    os_NewLine();
A tab size of 10,000 will let you calculate 10,000 primes up to 104,729. A tab size of 20,000 will let you calculate 20,000 primes up to 224,737. It takes 1 second to display 121,127 primes up to 1,600,000 on my iPad with the program above. On my TI84+CE, it takes 38 seconds to calculate 168 primes up to 1,000 .
You can optimize the declarations to decrease the size of your source file:
uint24_t p, z, a, x, i;
float q;
uint8_t f;
Ok :
void main(void)
    uint24_t p=0, z, a, x, i;
    float q;
    uint8_t f;
    char * ptr;
    char input[10];
    os_ClrHomeFull();
    for(z=2;z<=i;z++) {
        q=sqrt(z);
        f=0;
        for(x=1;x<=p;x++) {
            a=tab[x];
            if(a>q) {
                break;
            if((z%a)==0) {
                f=1;
                break;
        if(f==0) {
            if(z%2!=0) {
                p++;
                tab[p]=z;
                print(z);
            else if(z==2) {
                p++;
                tab[p]=z;
                print(z);
            else;
        if (os_GetCSC()) {
            os_NewLine();
            break;
    os_NewLine();
    char zstr[10];
    os_NewLine();
Note : I did have to initialise p to zero to silence an error.
are you using the TI-BASIC programme? This c program is way faster than that.
cemetech.net wrote:
SomeCoolGuy
Advanced Newbie (Posts: 69)
nice
Izder456 On my tI84+CE, I’m running a TI Basic version of my Lua program. It’s painfully slow, so I don’t do a lot of programming on it.
Page 2 of 2
