I'm afraid my limited supply of computer knowledge is running out. On the other hand, this will be an opportunity to expand it! 😁
How do you write an appvar into a binary file?
There's a readme for using convhex here: https://github.com/mateoconlechuga/convhex/blob/master/readme.md
If you have a file you want to turn into an appvar, run:
convhex -v -n APPVAR -f file.bin appvar.8xv
What file type should file be? Does the .bin mean it's a C file?
It can literally have whatever data you want in it. Text, image data, a tokenized program... It literally just takes whatever bytes are in that file and puts it into an appvar.
I need help with reading text out of an appvar.
I created a text file with "HELLO" in it and ran convhex. It converted it (and created "OmicronC.8xv" as the output file) and I sent it to CEmu along with this program:
[i]READ
CloseAll
"POINT"->Str0
Open("OmicronC","r")->SLOT
If SLOT=0
   Output(2,1,"Slot does not exist
Read(Str0,5,1,SLOT
Output(1,1,Str0
Pause
CloseAll
Whenever I run the program, it outputs "POINT" and the slot error message. How do I fix this problem?
Capitalization may matter, make sure it's right. Or just use all uppercase, that's what I do. It's also possible that you didn't convert the data right using convhex. The syntax looks right to me though (except for the fact that it should be "CloseAll()" instead of "CloseAll"). I would try using the code I posted earlier to write your message into the appvar, then see if your reading code works. If it does, it's an issue with the appvar. I hope this helps, good luck.
Thanks, I'll try that.
Edit: It worked, so I must be using convhex incorrectly. I'll try converting the text file a different way and see if that works.
Edit2: Here's my latest attempt: convhex -v -n APPVAR Clues.txt Omicron.8xv It doesn't work.
Edit3: convhex -v -n OmicronC Clues.txt OmicronC.8xv This one worked, but created a file that CEmu names OMICRONC. How do I tell convhex to keep the text format?
I can't reproduce that. When I use the same command I get the following file in CEmu:
Are you sure you are sending the correct file, and deleted the old one?
I deleted the old file and ran convhex again. This is what the PowerShell looked like:
In the file explorer, the text case is correct, but in CEmu it is still the same.
Are you using the latest convhex release?
https://github.com/mateoconlechuga/convhex/releases/latest
Now that I can read strings out of appvars, I was wondering about reading integers out of appvars.
Since ICE only supports 3-byte integers, I stored "001006" into OmicronC, thinking that the Read( command would eliminate the leading zeros to leave "16". However, none of the programs that I used returned 16.
This is my current one:
[i]READ
Begin()
CloseAll()
If SLOT=0
   PrintString("Slot does not exist
Alloc(6->L
Read(L,6,1,SLOT)->READ
If READ=0
   PrintString("Read Error
{L}->LENGTH
PrintUInt(LENGTH,2
Pause
CloseAll()
det(1
It returns "3223600" which, I think, is the address of L. I don't know how to fix this.
Can anyone help me?
Did you store bytes, or the string "001006" into the appvar.
[i]READ
Begin()
CloseAll()
If SLOT=0
Alloc(6->L
If READ=0
{L}->LENGTH
PrintUInt(LENGTH,2
Pause
CloseAll()
det(1
Can anyone help me?
Read(^^oVAR,3,1,SLOT
Write(^^oVAR,3,1,SLOT
3 is however many bytes of the number you want to read/write.
I stored the string "001006" into the appvar.
To beckadam:
Should I write the Read( command like this:
Read(^^oL,6,1,SLOT)->READ
To beckadam:
No, you'll need to write something that converts the text into a number.
You have two options:
Store the BYTES for the number into the appvar, or convert a STRING to a number in ICE.
How would you store the bytes for a number into a appvar? And how would you convert a string into a number?
Use some kind of hex editor, if you are on a crappy OS like windows.
irc wrote:
18:15 <MateoC> https://mh-nexus.de/en/hxd/
18:15 <MateoC> here you go
18:17 <MateoC> https://mh-nexus.de/downloads/HxDPortableSetup.zip
18:17 <MateoC> and there's the link
Thanks. Could you give me an example of how to do it? This is the first time I've used a hex editor.
Well once you open it, you can just start typing bytes in and save it as a file with a .bin extension. Bytes are represented in hexadecimal, if you are unfamiliar with that you can read more about it here: https://simple.wikipedia.org/wiki/Hexadecimal_numeral_system
Essentially the hex editor just shows what bytes are represented in a file. You can try opening the text document you made earlier to see what bytes it consists of. Let us know if you have any other questions! 🙂
For instance, if I wanted to write the number '16' to a file to be read by ICE, I would use the following 3 bytes:
10 00 00
Page 2 of 4
