I've been trying to load Doors CS onto my TI 84+, but whenever I launch it I'm met with a corrupted screen. When on this corrupted screen, no buttons work. I can't press CLEAR or QUIT to exit, and pressing ON just turns off the LCD; the corrupted screen remains when I turn the calculator back on. When I try to take a screenshot from TI Connect CE, I'm met with a transfer error. I've been able to take out a battery and replace it to exit the app with success. I've tried a full RAM+Archive reset, and still have the issue. I've been able to copy the same 8xk file to my other TI, and it works just fine. After opening the memory management screen on the broken TI, I can see a gui7(300B) and a DCS7(94B) file in RAM. Can anyone tell me why this is happening?
Try running this program before running Doors CS:
https://www.ticalc.org/archives/files/fileinfo/366/36608.html
Hope this helps, welcome to Cemetech
Thanks for the reply. I deleted everything from DoorsCS, moved LCD Fix to the calculator before moving DoorsCS, and tried again. Ran LCD Fix before DoorsCS; it returned a value of 63. Same symptoms occurred; distorted screen, only way to exit is with batteries.
It should be noted that pressing any arrow key causes a random block of distortion to shift.
I wish there was something better I could say, but it seems that Doors CS does use some form of a safe screen copy... Can you please try this program and see if the screen is still glitchy when you use it? I know what routine it uses so it will be helpful for the developer, and I could submit a patch.
https://www.cemetech.net/programs/index.php?mode=file&path=/83plus/asm/games/TheWorldsHardestGame.zip
Tried running the program; no graphical glitches at all. I can use the app normally.
Just to be sure, which calculator do you have? Is it a TI-84+ or a TI-84+SE?
It's a TI 84+, not an SE. I didn't have any programs on the TI before running Doors CS.
