I have a TI-84 Plus running OS 2.43. Some programs/apps I try to run end up with this broken display that's near impossible to navigate. I have tried downgrading to OS 2.43 and running LCD fix through MirageOS.
Unfortunately, it seems your calculator is too new for DoorsCS7 to work. TI seems to have changed something about the hardware on the newer models, causing Doors (and possibly other programs) to not function normally. As the community has largely moved to the CE, it is also not very likely that a fix will be found ☹️.
