When I use det(1 to exit graphic screen in ICE, it usually closes like intended, but on one of my programs it does the first pic. And when i press any button it does the second pic. Does anyone know how to fix this? https://imgur.com/a/fyuYLb8
What are you doing when you're exiting the graphics setup? Does the program end immediately, or are some other things happening? Looking at the source code might help.
That happens to me too.
This may be occurring because of subroutines that precede det(1. That function doesn’t end your program, so it keeps running subroutines until it finds a Return token. I think you can fix it by adding a Return.
https://imgur.com/a/euLhycS it ends at det(1
I should mention that the background is a tilemap, using ConvPNG
2D Minecraft CE did that too in the earlier versions. I used det(1) to enter what looked like a VR mode lol.
TimmyTurner62 wrote:
2D Minecraft CE did that too in the earlier versions. I used det(1) to enter what looked like a VR mode 0x5.
Do you know how it was fixed?Unfortunately, no I haven't
PT_ wrote:
Can't replicate, need more code.
We can't help you unless you give context for the error.
James_Rose wrote:
