On my Casio fx-cg50 calculator there is a usable examination mode that runs for 12 hours. In those 12 hours you are unfortunately not able to turn this mode off or to use certain features on your calculator . Is it possible to bypass the examination mode with a certain Downloadable software that let's you input a combination of buttons to exit this mode or to shorten the duration to let's say 1 hour... Or 1 minute?
No.
PT_ wrote:
No.
Could you go into more detail as to why? I'm not a calculator expert myself but it doesn't seem like an impossible task.
Exam mode exists for a reason, and it's certainly not the goal to somehow circumvent this. You are better off learning for this exam than trying to cheat. 🙂
Maybe I'm an impatient brat that doesn't really want to wait 12 hours to be able to use my calculator fully after making a test that was only 1 hour making my calculator incomplete for 11 hours.
Rather than the unhelpful reply you received, yes, it is possible to exit exam mode. Here's a guide on how to do it: https://support.casio.com/storage/en/manual/pdf/EN/004/fx-CG50_Soft_EN.pdf
See section β-3. It describes 3 different ways to exit exam mode. The section is called "Examination Mode" if you need help finding it.
Welcome to Cemetech, I hope that you realize that we aren't all terse 😛
Thank you, it's really frustrating not being able to properly use my Calculator, thanks for understanding 😁
Is there absolutely no way to bypass exam mode, or like even making a fake overlay. Only for educational purpose use.
Just want to see the potential use of my calculator.
Nothing will be said on this topic because even if you're not planning to cheat, others could also use this information.
Hi, I have a problem with my Texas Instruments TI-84 Plus CE calculator. I put it in exam mode "TEST MODE ENABLED:
TESTGUARD" and I can no longer remove it from this exam mode. I tried to reset it, remove it from the exam mode with the help of TI Connect CE but no chance. However, I found out that in the exam mode you can downgrade very simple, I connected it to TI Connect CE and installed OS 5.3.0.0037 from OS 5.8.2.0029.Anyone have any idea what I can do to solve this problem?Thanks in advance!
Your certificate memory area somehow got corrupted, it's rare but annoying as it can make the calc behave in bad/unexpected ways as you saw.
A (special?) build of CerMastr may help restoring it to "normal"...
Also, you should probably update to 5.4.0 (maybe even 5.4.1 if you're not programming ASM on calc directly)
