bikmin wrote:
Wow! Looks real impressive! RAM use is an issue, you might want to work on optimizing. Keep up the good work!
Optimizing stage will happen once I figure out why it's not working. I have a program called SCROLLV3. It's my 3rd scrolling world attempt that actually works properly.
I tried using CopyData() to save numbers to L1. But that's not working. Instead of the correct numbers showing when I display the lists contents, it has big numbers and the fourth number in the list is correct. I tried this:
:CopyData(L1,4,0,1,2,3
...and this:
:Alloc(4)->SIZE
:CopyData(L1,SIZE,0,1,2,3
but that doesn't work either. That's why I increment by 7s, but that eats up RAM! I need help.
