How do I change the color to text in a program for example
if A=1
Then
Disp "yes"
________________________________________________________________________
What command would I put and where would I put it to make "yes" green
You can't change the color of text. If you want colored text, use the graph screen with the Draw menu.
how do i get this to come from the top and slide to the center
Code: if A=1
then
disp "yes"
And I know that disp commands cant be used on the graph
Yes, that is correct, you can not use the 'Disp', or output command on the graph screen. You should use the Text( command to draw text on the graph screen. You should also turn axes and coordinates off so that they do not mess with your text. To change the color of the text, use the TextColor( command.
You can also change the color of text by using
textlib by DrDnar. It is simple to use and easy to integrate into your programs.
