I am using Chrome version 63.0.3239.132 on windows 10 pro.
I expected the image to be cropped down to a small size.
It was not very small.
I was able to replicate this in Microsoft Edge version 41.16299.15.0
I tried replicating this in Internet Explorer version 11.192.16299.0, and the issue got much worse.
Legoman314 is the only user I've ever seen this happen with, but his image is very large (1920x1200)
Here is a link to his profile
And here is a link to the picture.
Because I'm on CemetechRetro, it sort of messes up the whole page as well. (Not really, but it's annoying). I sometimes like CemetechRetro over Cemetech6, so...
I'm so sorry, I didn't realized it was that big, I have changed it to a 100x100 image. Hope it works.
It's soo much better! Thanks!
you're welcome!
Well, that's great and all, but there is still a problem... The purpose of this post wasn't to get you to change it, but rather to nag Kerm about fixing his site
Also, it appears they've locked the bug reports thread and now encourage users to make individual threads for each bug?
Looking at the css, there is nothing regulating the max-height and max-width of the profile picture, but there is some code for doing so when it is shrunk to put in posts. I think simply adding something like
Code: max-width:100;max-height:100;
to the profile_avatar class should do it, but I can't reproduce it now that it has been changed by the user. I think the image was taking up the width of the container (with some margin value) which is why it would appear the way it did, but that makes me wonder how all the other images managed to stay the right size.
EDIT: I've went and checked and the issue is a little bit less front-end. The user used the "Link to off-site Avatar" option. This option is probably very unpopular, which is probably why I've never seen this happen. When you upload an avatar from your pc, it checks and asks that the image be less than 29kb, but this check seems to not be present when linking to an offsite avatar. Somebody should have a look at the code for that, and somehow make it check that the offsite avatar is small.
Or just remove it, because nobody uses it .
That is correct. Makes the discussion easier to track in the long run.
Very astute observation! I'll add this to the issue list in the repo.
