So, I've been tinkering with programming for quite a while now. I've been through at least four introductory courses after teaching programming to myself on the calculator, and eventually moved on to Computer "programming" with HTML and CSS. Later, I accidentally (yes, you've read that correctly) learned PHP. I was stuck there for quite some time, and because server side only programming sucks, I learned JavaScript. But I have a problem: Those are all not a language of choice for an application outside of the web, and the web is not the direction I am planning to take.
Now, I did try a few computer languages. I had a go at C++ self-teaching ages ago, but I failed. I was recommended Python at Cemetech, but honestly, that didn't quite "sit" too. But a few months ago, I had a 1-week school internship, and apparently I applied to the correct department, because they gave me a book and a C++ crash-course. But so far all I did was either JavaScript or console applications.
So I figured "what if I try to teach myself how to make Windows Desktop applications?". Great, isn't it? Well, and then I opened a new, empty "C++ Desktop Application" project in Visual Studio. And I got this:
I have absolutely no idea what this does... 😕 I tried to search the web for good tutorials for this kind of thing, but none of the codes would compile in VS2017. Now, my question is, could anyone either link me to some tutorial they have tried or were recommended, or even get me started themselves? Are there any specific keywords I may have missed in my Google searches?
I intend to post my first one or two projects here, provided I manage to do anything.
// WindowsGUITest.cpp : Defines the entry point for the application.
#include "stdafx.h"
#include "WindowsGUITest.h"
#define MAX_LOADSTRING 100
// Global Variables:
HINSTANCE hInst; // current instance
WCHAR szTitle[MAX_LOADSTRING]; // The title bar text
WCHAR szWindowClass[MAX_LOADSTRING]; // the main window class name
// Forward declarations of functions included in this code module:
ATOM MyRegisterClass(HINSTANCE hInstance);
BOOL InitInstance(HINSTANCE, int);
LRESULT CALLBACK WndProc(HWND, UINT, WPARAM, LPARAM);
INT_PTR CALLBACK About(HWND, UINT, WPARAM, LPARAM);
int APIENTRY wWinMain(_In_ HINSTANCE hInstance,
_In_opt_ HINSTANCE hPrevInstance,
_In_ LPWSTR lpCmdLine,
_In_ int nCmdShow)
UNREFERENCED_PARAMETER(hPrevInstance);
UNREFERENCED_PARAMETER(lpCmdLine);
// TODO: Place code here.
// Initialize global strings
LoadStringW(hInstance, IDS_APP_TITLE, szTitle, MAX_LOADSTRING);
LoadStringW(hInstance, IDC_WINDOWSGUITEST, szWindowClass, MAX_LOADSTRING);
MyRegisterClass(hInstance);
// Perform application initialization:
if (!InitInstance (hInstance, nCmdShow))
return FALSE;
HACCEL hAccelTable = LoadAccelerators(hInstance, MAKEINTRESOURCE(IDC_WINDOWSGUITEST));
MSG msg;
// Main message loop:
while (GetMessage(&msg, nullptr, 0, 0))
if (!TranslateAccelerator(msg.hwnd, hAccelTable, &msg))
TranslateMessage(&msg);
DispatchMessage(&msg);
return (int) msg.wParam;
// FUNCTION: MyRegisterClass()
// PURPOSE: Registers the window class.
WNDCLASSEXW wcex;
wcex.cbSize = sizeof(WNDCLASSEX);
wcex.style = CS_HREDRAW | CS_VREDRAW;
wcex.lpfnWndProc = WndProc;
wcex.cbClsExtra = 0;
wcex.cbWndExtra = 0;
wcex.hInstance = hInstance;
wcex.hIcon = LoadIcon(hInstance, MAKEINTRESOURCE(IDI_WINDOWSGUITEST));
wcex.hCursor = LoadCursor(nullptr, IDC_ARROW);
wcex.hbrBackground = (HBRUSH)(COLOR_WINDOW+1);
wcex.lpszMenuName = MAKEINTRESOURCEW(IDC_WINDOWSGUITEST);
wcex.lpszClassName = szWindowClass;
wcex.hIconSm = LoadIcon(wcex.hInstance, MAKEINTRESOURCE(IDI_SMALL));
return RegisterClassExW(&wcex);
// FUNCTION: InitInstance(HINSTANCE, int)
// PURPOSE: Saves instance handle and creates main window
// COMMENTS:
// In this function, we save the instance handle in a global variable and
// create and display the main program window.
BOOL InitInstance(HINSTANCE hInstance, int nCmdShow)
hInst = hInstance; // Store instance handle in our global variable
HWND hWnd = CreateWindowW(szWindowClass, szTitle, WS_OVERLAPPEDWINDOW,
CW_USEDEFAULT, 0, CW_USEDEFAULT, 0, nullptr, nullptr, hInstance, nullptr);
if (!hWnd)
return FALSE;
ShowWindow(hWnd, nCmdShow);
UpdateWindow(hWnd);
return TRUE;
// FUNCTION: WndProc(HWND, UINT, WPARAM, LPARAM)
// PURPOSE: Processes messages for the main window.
// WM_COMMAND - process the application menu
// WM_PAINT - Paint the main window
// WM_DESTROY - post a quit message and return
LRESULT CALLBACK WndProc(HWND hWnd, UINT message, WPARAM wParam, LPARAM lParam)
switch (message)
case WM_COMMAND:
int wmId = LOWORD(wParam);
// Parse the menu selections:
switch (wmId)
case IDM_ABOUT:
DialogBox(hInst, MAKEINTRESOURCE(IDD_ABOUTBOX), hWnd, About);
break;
case IDM_EXIT:
DestroyWindow(hWnd);
break;
default:
return DefWindowProc(hWnd, message, wParam, lParam);
break;
case WM_PAINT:
PAINTSTRUCT ps;
HDC hdc = BeginPaint(hWnd, &ps);
// TODO: Add any drawing code that uses hdc here...
EndPaint(hWnd, &ps);
break;
case WM_DESTROY:
PostQuitMessage(0);
break;
default:
return 0;
// Message handler for about box.
INT_PTR CALLBACK About(HWND hDlg, UINT message, WPARAM wParam, LPARAM lParam)
UNREFERENCED_PARAMETER(lParam);
switch (message)
case WM_INITDIALOG:
return (INT_PTR)TRUE;
case WM_COMMAND:
if (LOWORD(wParam) == IDOK || LOWORD(wParam) == IDCANCEL)
EndDialog(hDlg, LOWORD(wParam));
break;
return (INT_PTR)FALSE;
}I have absolutely no idea what this does... 😕 I tried to search the web for good tutorials for this kind of thing, but none of the codes would compile in VS2017. Now, my question is, could anyone either link me to some tutorial they have tried or were recommended, or even get me started themselves? Are there any specific keywords I may have missed in my Google searches?
