What is a Solar Eclipse?
A Solar Eclipse is when Earth's Moon intersects light coming from the Sun to Earth. Solar Eclipses don't happen often because of the Moon's orbit, which is not even with Earth. But, basically, a solar eclipse is when the Moon casts a shadow on Earth.
What is the Science Behind a Solar Eclipse?
A Solar Eclipse happens when the Moon travels between the Sun and the Earth. Due to the tilt in the Moon's orbit, it often passes below or above the Sun but every so often it gets between us and the Sun. Most of the time the Moon eclipses part of the Sun, creating a Partial Solar Eclipse. But every once in a while the Moon enters the direct plane between the Sun and Earth, creating a Total Solar Eclipse.
During a Total Solar Eclipse a Partial Solar Eclipse is visible in the areas outside the Moon's full shadow, or the Umbra. The areas within the Partial Solar Eclipse fall in the Penumbra. The regions of Earth who fall within the Umbra is called "The Path of Totality."
Try This at Home!
Grab a flashlight and a small object, like a tennis ball or even your fist! The object doesn't need to be round but it will help demonstrate what's happening. The flashlight will be the Sun while the object will be the Moon. Find a wall and that'll be Earth. Shine the light on the wall and move the object into the path of the light. The dark center is the Umbra, the region where the object completely blocks the flashlight from hitting the wall, the gray areas are the Penumbra or the areas where the object partially blocks the flashlight.
Does a Total Eclipse Have Any Effects?
There are no long term affects, it's merely a phenomenon. There are short term effects however! In the umbra the temperature can dip several degrees. In fact, NASA has an experiment you can do at home! They encourage you to download their app and get a thermometer. Before the eclipse register the temperature on their app, then record the temperature again during the eclipse. You can do this experiment whether your in the umbra or penumbra.
Since the Sun is blocked by the Moon, the sky will darken. More so in the path of totality than outside of it.
Read More at NASA!
Safety Information
DO NOT LOOK AT THE SUN. Ever. You will need solar glasses to look at the Sun. Or, you can look at the shadows cast by leaves from trees. During a partial eclipse the light that makes it through the trees will be crescent Moon shaped, it's really cool! So you can use the shadows to watch the eclipse or you can make some other tools, such as a cereal box viewer.
The Cemetech Community
Are any of you guys making a pilgrimage to see the Eclipse? If so, what are your plans?
Try This at Home!
Read More at NASA!
Safety Information
