Hmm... So I was trying to figure out how to display a cube that could be rotated in all directions. I want to find a formula that converts an (x,y,z) coordinate to an (x,y) coordinate. However hard I looked online, I could not find such a thing. Any help would be welcome.
The screen I am using is 320x240, but any example would be fine, just so that I could grasp the concept.
That looks like the calc screen size...
Short version:
x2d = xOffset + scale * x3d / ( z3d + distanceFromCamera)
y2d = yOffset + scale * y3d / ( z3d + distanceFromCamera)
Long version:
Read this article that I grabbed the earlier code from.
I also delved into the world of 3D myself, and even made a calculator thingie from it! link here
Frankly understanding how 3D -> 2D works without having experience with something like openGL or directx cab be daunting, but basically:
Step 1: all 3D input points are transformed and rotated based on the players position and rotation. Thus, instead of being relative to the world or model origin, these points are now relative to the player. (Vertex shader on modern GPUs)
Step 2: these player-relative 3D points are then projected into 2D.
Step 1 is done with trigonometry, look up "rotating a point in 3D space" if you need help. Step 2 is done with the above posted formula, plus some more math to take care of FOV.
EDIT: check out this neat gif
It's not rotating correctly because ICE doesn't support sine or cosine Sad
Thanks for all the help! I think I have this working, but I need to figure out rotation to see if it is actually doing what it's supposed to.
Here is a screenshot:
And the code (in ICE):
iCUBE
det(0
det(5,0
det(2,255
For(X,1,8
0→L₁(X)→L₂(X)→L₃(X)→L₄(X)→L₅(X)
0→L₁(1)→L₁(3)→L₁(5)→L₁(7)
1→L₁(2)→L₁(4)→L₁(6)→L₁(8)
0→L₂(1)→L₂(2)→L₂(5)→L₂(6)
1→L₂(3)→L₂(4)→L₂(7)→L₂(8)
0→L₃(1)→L₃(2)→L₃(3)→L₃(4)
1→L₃(5)→L₃(6)→L₃(7)→L₃(8)
For(A,1,8
50+50*L₁(A)/(L₃(A)+2)→L₄(A)
50+50*L₂(A)/(L₃(A)+2)→L₅(A)
det(30,L₄(1),L₅(1),L₄(2),L₅(2)
det(30,L₄(2),L₅(2),L₄(6),L₅(6)
det(30,L₄(6),L₅(6),L₄(5),L₅(5)
det(30,L₄(5),L₅(5),L₄(1),L₅(1)
det(30,L₄(3),L₅(3),L₄(4),L₅(4)
det(30,L₄(4),L₅(4),L₄(8),L₅(8)
det(30,L₄(8),L₅(8),L₄(7),L₅(7)
det(30,L₄(7),L₅(7),L₄(3),L₅(3)
det(30,L₄(1),L₅(1),L₄(3),L₅(3)
det(30,L₄(2),L₅(2),L₄(4),L₅(4)
det(30,L₄(6),L₅(6),L₄(8),L₅(8)
det(30,L₄(5),L₅(5),L₄(7),L₅(7)
Pause
det(1)
You can't do rotation properly without sin(). Use a look up table I guess?
I actually quite like the above gif, even if it isn't fully accurate to 3D
You can also use a Taylor Series to approximate sine and cosine.
sin(x) = x - (x^3)/(3!) + (x^5)/(5!) - (x^7)/(7!) ... (-1)^n * (x^(2n+1))/((2n+1)!)
cos(x) = 1 - (x^2)/(2!) + (x^4)/(4!) - (x^6)/(6!) ... (-1)^n * (x^(2n))/((2n)!)
Just extend the series as long as necessary.
I am interested in using the Taylor series, however I am confused about how to go about doing so. I assume I choose a finite number of terms, the more terms added the more accurate. After searching online about the Taylor series, I saw nothing like (-1)^n * (x^(2n+1))/((2n+1)!), and just the other parts of the series don't seem to give something similar to sine. Is the bit at the end added to the rest? Where does it fit in (i.e what does '...' represent)? I assume n is the number of factorials used.
Also, a new gif that looks a ton better (I used double buffer PT Very Happy)
_iPhoenix_ wrote:
Short version:
Long version:
link here
to simplify things a little bit you could just say this --->>
x = x / z
y = y / z
kotu wrote:
_iPhoenix_ wrote:
Short version:
Long version:
link here
x = x / z
y = y / z
No scale is to make the FOV correct :V
The +distancefromcamera isn't needed though, as all rotation and translation should be done before projection, but it works for a quick demo.
Basically, it means that the series continues infinitely following the rule (-1)^n * (x^(2n+1))/((2n+1)!), where n is the place in the series.
For example, the series 1x^2 + 2x^3 + ... nx^(n+1) can be expanded to be 1x^2 + 2x^3 + 3x^4 + 4x^5... nx^(n+1), as the terms I added follow the rule nx^(n+1), and n incremented by 1.
note to self: power rule is great for demos
_iPhoenix:
The link you posted was extremely good... thanks, Dik
