Edit by Alex/comic: Split these posts from the General Minecraft Screenshots Topic. Please post all Cemetech 1.9 Server Screenshots here!
Some screenshots from our Minecraft 1.9 server! Caution: I often run Minecraft at high resolution. You've been warned.
Nearly-completed spawn, in the daytime.
Completed spawn, at night. You can't see the blimp, unfortunately.
The server's first beacon, the result of much wither battling! It lies above my temporary base.
...and the server's second beacon, next to my first.
Edit #2: I moved the three Elder Guardians from the Ocean Monument I have claimed into safe storage. Here are a few screenshots of the progress. Because I didn't find sponges yet, I omitted the painful process of building water-free tunnels within the monument to reach each of the Elder Guardians, and the shaft down to a pool at Y=11 in order to put them onto a Minecraft railroad. I built a 3x3 tunnel leading to underneath my base, with three 5x3x3 holding pens for the Elders. Here is the first Elder Guardian traveling along the rail to its storage pen:
The third and final one, surrounded by a daunting array of its followers, at the bottom of the drop shaft:
All three, safely ensconced:
The station area, under construction.
Station second floor.
Station first floor.
Outside view of the station, completed portion of track.
