How do I check whether a file exists?
If a program is hidden, then you need to go into DoorsCS/CSE to see it. Hiding programs "removes" them from the programs list (when you press [PRGM]), so that you will only be able to see them in Doors
If you use DoorsCS, you can use
det(9, if you use DoorsCSE, you can use either use
0:det(0 to get the amount of lines, if a program doesn't exist, Str9 should be an error, or theta=0. You can try ReadLine as well. Hope this helps!
