erm, can you expand the snips please?
iPhoenix
- hi (Posts: 1862)
- 28 Mar 2017 09:11:58 pm
- Last edited by iPhoenix on 29 Mar 2017 06:52:54 pm; edited 1 time in total
Badically, each subprogram is like a class, the first part of the input is a function call, and the rest are arguments.
Yes.
<s n i p>
One could say I'm making Ti-BASIC OOP again! (and OOP is great!)
If this is what I have to deal with: no code
10:30:57 PM ***prgmTrouble got back from picketing
10:30:32 PM [Cemetech] prgmTrouble entered the room
10:30:14 PM ***prgmTrouble pickets outside _iPhoenix_'s residence
10:29:01 PM [prgmTrouble] It's a conspiracy to deprive us of the code
10:24:29 PM [mr womp womp] _iPhoenix_ we demand the code
10:23:11 PM [Cemetech] calcnerd_CEP_D entered the room
10:22:45 PM ***Battlesquid facepalms
10:22:26 PM [mr womp womp] CODE ME DADDY
10:21:46 PM [oldmud0] CODE PLS
10:21:02 PM [Cemetech] Luxen entered the room
10:15:32 PM [Cemetech] _iPhoenix_ edited a post in [Neural Network!]
Support the community by joining MyCalcs for free! Co-founder of TI-Toolkit.
*bump* Code released on Wednesday, March 29, 2017
See first post.
See first post.
- mr womp womp
- Official Cemetech Cat Manager (Posts: 1781)
- 29 Mar 2017 06:26:20 pm
- Last edited by mr womp womp on 29 Mar 2017 06:43:41 pm; edited 1 time in total
Here, have some optimizations.
Could be
Could be
Could be
Didn't test this, but I think this should work...
Could be
Could be
1
If 2S<5
~1
Ans->theta
Could be
1-2(2S<5->theta
{randInt(~100,100),randInt(~100,100->|LZYZYZ
Could be
randInt(~100,100,2->|LZYZYZ
1
If (2|LZYZYZ(1)-5)>|LZYZYZ(2
~1
augment({3,Ans},|LZYZYZ->|LZYZYZ
Could be
augment({3,1-2((2Ans(1)-5)>Ans(2))},Ans->|LZYZYZ
DelVar S
For(I,3,dim(|LARGS)-1
S+|LARGS(I)*|LWTS(I-2->S
Could be
sum(seq(|LARGS(I)*|LWTS(I-2),I,3,dim(|LARGS)-1->S
If 1=|LARGS(1
Then
|LARGS(2->dim(|LWTS
For(I,1,Ans
2rand-1->|LWTS(I
Could be
If 1=|LARGS(1
seq(2rand-1,I,1,|LARGS(2->|LWTS
Could be
Could be
Could be
Could be
Could be
1
If 2S<5
~1
Ans->theta
Could be
1-2(2S<5->theta
Could be
1
~1
Could be
DelVar S
Could be
If 1=|LARGS(1
Then
|LARGS(2->dim(|LWTS
For(I,1,Ans
2rand-1->|LWTS(I
Could be
If 1=|LARGS(1
Much thanks!
It already ran fast, but now it's much better. I'll add those revisions when I am not on mobile.
Thanks!
Here's the code with Womp's optimizations:
prgmPERCEPT:
Ans->|LARGS
0.1->C
If 1=|LARGS(1
If 2=|LARGS(1
Then
DelVar S
1-2(2S<5->theta
If 3=|LARGS(1
Then
|LARGS(2->D
dim(|LARGS)-2->dim(|LA
DelVar S
1-2(2S<5
Ans->G:Ans->S
D-G->E
For(I,1,dim(|LWTS
C*E*|LARGS(I+2->|LB(I
|LWTS(I)+C*E*|LARGS(I+2->|LWTS(I
{E,S,|LB(1),|LB(2
prgmTRAIN:
ClrDraw
{1,2:prgmPERCEPT
Input "NUMBER OF TRIALS: ",A
A->|N
Ans->PV
0->I%
1
Repeat not(|N
1->dim(L1
prgmPERCEPT
Ans->L1
Pt-On(|LZYZYZ(3),|LZYZYZ(4),Black+L1(2
Disp Ans,|LZYZYZ
If not(L1(1
Then
I%+1->I%
Disp Ans
|N-1->|N
Disp I%n/dPV
And here's the README file (text, have fun putting this on your calc), for archival purposes (and for help):
Drag both onto CE/CSE (monochrome may work)
Launch prgmTRAIN
Do not change the name of prgmPERCEPT.
Bugs/Modifications are welcome.
If there is any code that doesn’t run (I’m talking about stuff in prgmPERCEPT), it is there for later versions.
Thanks!
~iPhoenix
Bugs<snip>are welcome.
What a generous policy!
Most developers I know try to eliminate them immediately.
I'm not too experienced with using neural networks, but this still looks like an interesting project.
Have neural networks been created with ez80 assembly before? Obviously, the program will be very slow once multiple neurons are introduced, and I wonder what the "maximum" speed on a calculator would be using assembly.
It would, but assembly is hard and causes a crash when a mistake happens. Basic is used here mostly for conceptual purposes.
Only if you don't know what you are doing...
So pretty much everyone except you and a handful of others.
Part 1: Thanks!
Part 2a: I don't know assembly, and that'd take away the fun! (This would be easily accomplished in C, IIRC, but non OOP is more challenging)
Part 2b: It's actually not going to be that slow. Here's my (simplified) logic:
We only need to use 2 programs: One that has the perceptrons, and one that organizes the network (and one that trains, but whatever)
We can have different weights/inputs by specifying different parts of the lists. I could modify my "syntax" 'making TI-Basic OOP again, and OOP is great!" - Meby making it so that you specify a single perceptron in the network. Currently, the syntax for training a perceptron is:
{3,[expected result],[input1],[input2]...[input n]
but this can easily be turned into
[number of inputs per perceptron]->n
{3,n,[expected result1],[perceptron number],[input1],[input2]...[input n],[expected result2],[perceptron number],[input1],[input2]...[input n]
I should probably get started, eh?
CalcMeister wrote:
When will you use ICE for heavens sake? Speed is key for all of these projects!
Yes, I have started learning ICE, yes speed is key, no, there aren't any decimals.
That last part is killing it for me
<edit>
Also, code for a rudimentary ANN is working, but freaking back-propagation.
Crud!
You just posted that in the TI-BASIC forum...
PT_
- Site Admin (Posts: 2088)
- 01 Apr 2017 08:18:14 am
- Last edited by PT_ on 01 Apr 2017 08:37:34 am; edited 1 time in total
can be
That, in combination with
1-2(2S<5
Ans->G:Ans->S
D-G->E
can be
~1+2(5>2sum(seq(...->S
Ans->G
You can also remove G, and use D-Ans->E instead.
EDIT:
If not(L1(1
Then
If not(L1(1
PT_ wrote:
can be
1-2(2S<5
Ans->G:Ans->S
D-G->E
can be
~1+2(5>2sum(seq(|LARGS(I)*|LWTS(I-2),I,3,dim(|LARGS)-1->S
Ans->G
Thanks!
[edit]
No idea how THAT managed to get in the code.
I am currently unable to post the new version of the code (#mobile), but it does away with that section and improves it.
Also, backpropagation hype!!
I would like to say that this project is not dead and I am still trying to get my algorithm to work.
I'd say I'm 70% done, but my calculator keeps becoming sentient. (jk about the last part)
Calc: Wassup!!!
IPhoenix:
Calc: Hellooooo? I'm talking to you!!!!
IPhoenix: Uhhhhhh.... Hi?
Calc: Good. Human life is sentient. It would be a shame to destroy a planet filled with dum-dums.
*Randomguest smashes calc*
Randomguest: You're welcome.
IPhoenix:
*two minutes later*
IPhoenix: ALL.....MY....WORK....RUINED
Randomguest: Hey, I was just trying to help! Let go of me!
*Randomguest gets thrown out a window*
IPhoenix:
IPhoenix:
*two minutes later*
Nice.
I back up my calc twice daily, (#lessonlearned) once to my computer, then to my friend's computer (one backup is NEVER enough.)
Most people (at my school, that know me) know I back it up to 2 locations, but they only know I back it up to my computer, so it's a common joke that I back it up to my washing machine.
Stupid idiots, I'm not that smart.
*bump*
I did it. I made it a neural network!
Although it only has one layer, it should be able to solve the xor problem easily. (in a day or two) I recommend running the code in CEmu, with the throttle set at 500%, and perhaps removing some of the
tokens, to speed it up.
Have fun!
Disp
Have fun!
» Goto page Previous 1, 2
Page 2 of 2
