Woodland Mansion Raids
A new event on the server is the Woodland Mansion Raid. Woodland Mansions are a new structure introduced in Minecraft 1.11. Due to the fact that we've already reached maximum map size for the over world and the incredible rarity of Woodland Mansions, I've decided to set up an event around them. Woodland Mansions offer some perks, such as Totems of Undying when you kill one of the new mobs inside of them.
Prizes
The prizes can consist of the following:
What are Deeds?
A deed is something I've personally introduced into the game. Towny allows Admins to give out bonus plots, basically allowing a town to expand beyond it's maximum limit. The deeds I put in the mansion will vary between 1-5 extra plots. The harder it is to find, the more plots you earn. 1 plot deeds will be the most common, so don't get your hopes up for anything more than that too often. If you find a deed, you may give it to comic to have those plots applied to your town. Or, you may sell it.
What prizes are guaranteed?
Nothing! Mansions can consist of these prizes. Just because it's on this list doesn't mean it's going to always be in a chest somewhere. There could be a Mansion that has no Elytra, there could be a Mansion that's loaded with Lapis or with a little bit. Prior to this topic, I used to say what was available in the Mansion but going forward I won't say what's there to find.
Rules
You have 20 minutes to conquer a Hard difficulty Woodland Mansion. There are chests with items throughout. Be careful as there plenty of mobs - and maybe traps! - trying to kill you. This is not a vanilla Mansion. An admin will have spent time putting items into chests, placing new chests and, possibly laying traps.
Play as if you will not be brought back into the Mansion world. Play carefully, play smart. If you play with a team mate, communicate! Explore and be thorough.
Can more than two people play?
No.
I died before I even entered the mansion!
This will be evaluated on a case by case basis, but assume no.
I'm going to sneak some items in!
While this won't disqualify you, I will check your inventory prior to the match starting. Forbidden items may or may not be given back.
What is the time between games?
It depends! I reset the woodland mansion after each match and consequently re-hide items. So it may be 30 minutes or so. If there's enough prior interest I may prep a couple woodland mansions for back-to-back events. Usually this event will be around for the weekend and then not return for a while.
Can I play twice?
No! You may not play twice in the same day.
I died! Can I at least get my stuff back?
No! I suggest you play with a team mate so they can pick up your items and that you play with gear and items you are comfortable losing.
Is it really that hard?
From the few rounds we've done, it seems to be relatively easy! Just play smart and be aware of your surroundings.
Feel free to use this topic to discuss raids and post screen shots!
Prizes
- Elytra
- Totems of Undying
- Deeds
- Lapis Ore
- Effect Arrows
- End Cyrstals
- Diamonds
- Emeralds
- Enchanted Armor
- Enchanted Weapons/Tools
- Mob Eggs
What are Deeds?
Rules
- A team of 2 enters the mansion.
- You can either work as a team or compete against each other.
- No killing each other!
- 20 Minutes to conquer the mansion.
- If you die, you can't come back in.
- Any armor, weapons and, potions are permitted.
- No Ender Chests
- No Eggs
No.
Can I play twice?
