So I'm trying to upload a program to the TI 83+ (on jsTIfied) and it is not receiving it, any suggestions?
(assuming that it is on your computer) use ti connect ce, with a built in program editor, then copy ad paste the code into sourcecoder, then click the test button.
No, ti-connect CE will not work with your ti-83+, instead, use tilp or the old ti-connect (there are others but I am not too familiar with them). Now as for Jstified, you will first have to make sure that you have uploaded a good calculator ROM or else it won't emulate anything. Here is a quick tutorial on how to extract your calculator's ROM if you haven't already done so. Once you've got that done, you should be able to use the calculator just fine. Then all you have to do is send the app using the "⇧ Upload Programs/Files to Calculator" tab. When you send an app, it sends it instantly and the progress bar doesn't fill up, but it was still sent.
While you can't transfer the files, TI connect can still open TI-BASIC programs. Even if it would be unable to save the file, it should be able to read it.
However, seeing as OLB1 has a chromebook, this point doesn't really help solve the problem.
Another solution is to just type the code into sourcecoder. It is a pain, but even I have had to use that method before.[/b]
- Alex
- Official Cemetech Site Manager (Posts: 7912)
- Re: TI 83+ app problems (jsTIfied)
- 18 Nov 2016 02:46:32 pm
To get back to the problem at hand, where is this program saved on the Chromebook and what program is it? (with a link to the files webpage/download, if possible)
