I'm in favor of SourceCoder 3 syntax because I like the idea of the future possibility of getting code directly from the Wiki into SC3 for testing.
It seems to be getting rid of underscores in usernames...
I was fixing up some of my old contributions and some math formatting didn't translate. I attempted to fix it, but it seems that the <math> tag doesn't quite work yet.
EDIT: In particular, Exponentiation
I'm afraid I'm not spotting the errors. Sad The <math> tag should theoretically use standard LaTeX syntax, though, and the rendered version of the math in the Exponentiation section matches what I'd expect from the markup. Smile
I did some searching around, and unfortunately, there doesn't seem to be a way to encode a literal underscore in a MediaWiki page title. I can try to find a workaround, or write a hook.
I had this issue as well. Hopefully there is some fix, but it isn't the biggest loss.
So I've noticed this when reading things, but the code (when you move something in one space from the textbox) is just made a different font, making it hard to discern code from text.
I think that like other wikis (DCS) the code box should be a different shade of gray, or white.
Page 2 of 2
