??? Isn't that longer code what you just did for dividing? In order to differentiate between what needs FPM and what needs just 16-bit or 8-bit math, you would need either a statically typed language, or use a JIT to analyze what type of an object is at execution time.
Why? Well, what type would you consider Ans to be? Its type is essentially undefined until runtime. Is A / 2 an 8-bit integer, a 16-bit integer, or a floating-point integer, and is it signed? When you do A + B, can you do the "shortcut" method of addition or must it pass through a _bcall if it is a floating-point integer? These questions cannot be answered until the program is run, or types are specifically defined for each variable.
