Apparently Axe changed the ^ to take a module of something, is it still possible to get a power of a number or is it completely removed?
here is the code that I have now
Code: 2->G
15*(1.15^G)->H
There's no builtin way by default, as far as I can tell. You may want to look at exponentiation by squaring if you want to implement it yourself as a function.
Code: 2->G
15*(1.15^G)->H
For some reason this reminds me of Cookie Clicker's price-calculating function...but whatever.
I would assume that, for A to the power of B, where B is an integer power >1, you could simply do something like this (this is pseudocode; thinking about the most optimized way to code this in Axe will hurt my brain):
A -> C
Repeat B-1 times
C * A -> C
EndRepeat
where C is the result.
I think that kind of thing would be trivial, but one thing's for sure: don't use the ^ operator for it.
Please note that I don't know Axe.
As Mateo said, exponentiation by squaring is faster, and the algorithm is simple:
Code: def pow_squaring(base,exp):
result = 1
while exp:
if exp%2: result = base * result
base = base * base
exp >>= 1
return result
However, if you're only dealing with small powers and 8.8 fixed point, exponentiation by repeated multiplication will probably be fast enough.
