I have a ti-84 cse and I have gotten into assembly programming, I really want to know how play sound out of the link port, I mean I know sound is produced by sending bytes through the link port but I don't know how exactly to do that, so any help will be greatly appreciated!
An out instruction to port 0 will do the trick.
Here's the relevant wikiTI page:
http://wikiti.brandonw.net/index.php?title=83Plus:Ports:00
ld a,0 ; Set both lines high
out (0),a
ld a,2 ; Set tip high, ring low
out (0),a
ld a,1 ; Set tip low, ring high
out (0),a
ld a,3 ; Set both low
out (0),a
out (0),a
out (0),a
out (0),a
out (0),a
Oh okay, well do you know how to play specific frequencies.
edit:btw I tried the code above but it didn't seem to work, suggestions anybody?
After doing some more research I found that sound can be made by changing port 0 from 0 to 3 back and forth at a certain frequency but I can't find any example code that would show me how to do that.
Btw, I found my information here, https://www.cemetech.net/forum/viewtopic.php?t=5240
