- [Resolved] Dispenser egging not working
- 24 Nov 2015 11:45:40 am
- Last edited by tifreak8x on 13 Dec 2015 05:27:21 pm; edited 1 time in total
So, I decided to try my hand at building an egging machine around a spawner, so I could stock up eggs for a future project that will be taken more seriously on 1.9 map than on 1.8.
Anyways, After getting my egging machine built, letting eggs build up, and finally testing the system, I realized that the system isn't working, and it's not from eggs not getting launched at the mobs. I went through nearly 18 stacks of eggs very quickly while the zombies were not being captured.
Thinking I did something incorrectly, I took to Arcadia's town core to test the known working system there. Sadly, I got the same results there with the pigmen, and ended up having to go in and manually kill them off.
I'm not really sure when the last time the egg catching plugin was updated, but was wondering if it has been in the last few months (I've not even tried using an egger since we won this adventure event and wanted to get a few backup eggs from our winnings.
The only other thought I might have in regards to the issue is the fact that we upped the difficulty from Easy to Normal. Could this have caused an issue with the plugin? Is there a setting in there to possibly change to make it work again?
Comic tested and could manually catch mobs.
I want to change the catcher in arcadia to try to catch cows, and see if it is still broken with them.
Anyways, figured this would be a good place to record what gets tried, and eventually what fixes the problem.
