Had some thoughts on how to get sound out of the 84+ CE. I'm not going to try and implement it myself since I don't have a CE and there is no point in getting one for me either, but I thought I'd share the idea anyway.
Well, as you know we can't use the analogue link port anymore But what we can use is the D- line of the USB. So the first step is to make an USB -> sound adapter.
Basically you'd just need to connect pin 2 (white line) to the tip of a mono jack, and connect pin 4 (black) to the ground. Perhaps it'd need some extra resistors/caps/whatever though, who knows.
Now for the software side. First, one should probably power off the USB. Now to make sound, you can use the usual link port tricks, alas only in mono (but with 2 volume levels). Instead of using the link port however, you'd toggle bits 3 and 4 of port 0x4A. Right?
DISCLAIMER: It's just an idea, and my knowledge of both USB stuff and electronics is very limited. So unless you feel like blowing up your brand new CE, don't try this at home folks
