assemblybandit wrote:
Wow readroof2 you won? That's crazy if your backspacing worked. I got denim. Me thinks the planet question has someting to do with it, I chose earth, maybe the reds chose mars?
How many times did you enter the contest? You probably could have won by making a lot of entries instead of buying one.
readroof2 wrote:
I saw your video of the unboxing of the CE. The speed tests were amazing. Is it that much faster just because the processor got an upgrade?
Actually, the faster processor is not the main reason it appears so much faster. Although it has a nice up-to-48MHz ez80 CPU, wait states mean that when executing from flash, it effectively runs at more like 8MHz. The real speed boost is from the fact that it has a memory-mapped LCD, which makes writing to the LCD and updating its contents so, so much faster.
I'm just going to point out that if you have Windows XP, TI-Connect CE freezes on the splash image.
I'm not sure that's still the case, but it was initially. I made a joke about doing that, and then KermM actually wrote a script to actually do it, and ran it for like 100 entires. And then, at T^3 this year, somebody from TI told him they did, in fact, notice.
Actually, that's not really it, either. The real reason is that the Z80's IN and OUT instructions are SUPER slow---like 16 clock cycles per write. The eZ80's pipelining reduces it to 2 if there are no wait states. The wait states are a serious performance issue, though. With hand-written assembly, the eZ80 at 48 MHz can't even manage twice the MIPS as the Z80 at 15 MHz. Although, C will probably get at least twice the MIPS, due to C's use of the index registers, which were terribly slow on the Z80, but are actually quite nice on the eZ80.
I think what's going on is that the ASIC is using ARM logic blocks with an eZ80 CPU. The ARM normally has a cache, so the 3-state latency doesn't hammer performance the same way it does on the cache-less eZ80.
Don't use Windows XP. It hasn't been supported by MS for over a year.
Was Kerm able to win? I entered over 100 times manually and won.
That price is horrible! Who would try to sell a TI-84+CE at that price? Shouldn't it be like 130 dollars or something?
