Hey, see here my code:
Code: min({10,theta/2,max(1,A+sum(DeltaList(K={12,11->A
Exactly from SC!! But when I transfer it to jsTIfied, it gives a syntax error. What's wrong? . I'm sure the last part with sum( etc. gives the error.
Can you take a screenshot of what it looks like in the program editor in jsTIfied?
The problem is that you're nesting lists. Although the final result should resolve to a number, during the computation you're attempting to put a list in a list, which the calculator can't handle.
In this case, you can easily modify the expression to represent the same computation without nesting lists:
Code: min(10,min(theta/2,max(1,A+sum(DeltaList(K={12,11->A
