So let's say that I have a string of text with "Then chaos ensued..." and I want to display it character by character using, for example, the following 84+CSE BASIC code:
For(Z,1,21
Output(1,Z,Sub(Ans,Z,1
For(X,0,200
Then how would I make sure that SourceCoder doesn't parse "Then " and "..." as the Then instruction nor the ... token? I know that to prevent pi from being parsed as the pi symbol you can use [p]i instead, but I cannot seem to find any equivalent code distinguishing specific tokens from individual lowercase letters in the list of tokens/instructions and I did a forum search for "Sourcecoder lowercase problem" without the quotes, to no avail.
Another thing I have tried to ensure that the three dots are displayed as separate characters was to edit the code on-calc, then upload the file to SourceCoder, but then when exporting to the calc after saving my project the ellipsis token was back.
Thanks in advance.
It's easy! Just use the backslash character: Th\en, p\i, m\u, ..\., and so on. The backslash character forces a token boundary, so if you separate the h and the e in "Then", all four characters will be separate tokens, because "Th" and "en" aren't tokens either. Makes sense? Smile
Welp, why didn't I think about this? >.< Thanks for the suggestion. Smile I wonder if this could be a nice addition somewhere on the SC page in case people need help about it?
EDIT: Much better (although from entirely different program)
Before
After
