I've tried this on TI-OS 2.43 with DCS7.2b1 and TI-OS 2.55MP with DCS7.2 Final.
sonicrules1234 wrote:
If you run the program, and get it to error, several things stop working, and take a RAM Reset to fix. One of those things is turning the calculator off.
In fact, this bug can be replicated with only the following: SourceCoder 3 (TEST) wrote:
:ClrHome
:Lbl 1
:Input "",A
:randInt(~100,100)->B
:Disp B
:Goto 1
:Lbl 1
:Input "",A
:Disp B
:Goto 1
Input "",A
*bump* I've noticed another Doors CS 7.2 bug of my own while testing out the Spark Core stuff. In some cases, running a program that enables (and then presumably subsequently disables) CALCnet2.2, then trying to quit HomeRun, quit Doors CS, or run another program causes the run indicator to run and the calculator to require a battery pull.
I made an appvar from a program using the det(0,fileName,2) and it worked. But then, when I ran it again, the appvar disappeared but didn't reappear as a program. I tried the whole thing again, but then the appvar wouldn't switch back!
What filename did you use? Is it possible you chose a name that would make the TI-OS think the program was hidden (ie, not an uppercase letter)?
No, I just called it APPVAR.
Edit: Hehe, yeah... About this... Reading the SDK really helps... It's not a bug, I just didn't put rowSwap(... Sorry about that!
i found a bug thats not bad just kind of wierd.
When you edit a basic program in Doors, from the doors app itself and not from the homescreen, and you press mode than it displays a white screen but you can still select different items in mode, you just can't see what your selecting.
When i exited out of Doors after this happened, just now, my calc crashed and cleared the ram. luckily i was smart enough to back up my stuff.
I found a minor bug: If you are on the first page in the root folder of DCS then open a folder, go to the second page, and go back up to the root folder, you end up on page 2 of the root folder, not page 1.
https://ivoah.net
I knew that Y is a little erratic in the TI-OS but the above doesn't happen when DCSE isn't installed.
I'm also getting similar behavior on my TI-84 Plus with DCS7.2, except Y is 0. Probably something with the graph screen going on there.
Edit: disabling DCS libraries and hooks returns normal behavior.
I'm not getting this at all, even with the libraries and hooks enabled...
EDIT: Oh yes, changing the window affects this.
When Xmin = -10, Xmax = 10, Ymin = 0, and Ymax = 1, the answer is 0.
IRC wrote:
<Ivoah> KermM: Let me try to rephrase it, *ahem* When a BASIC program throws an error and brings me to the error screen, pressing "2" to go to the error just brings me to the homescreen without clearing the text, and a ram-clear usually follows shortly after
https://ivoah.net
As I said on IRC, I need some context. Obviously the vast majority of 2:Gotos work fine, because programmers use Doors CS and would complain. You probably have a syntax error in Asm(prgmXXX or expr(.
Here's the program that was causing errors: http://hastebin.com/kivixusoqo.coffee
https://ivoah.net
Which error? Can you tell to where your code gets before the error triggers? Which version of Doors CS are you using?
I have a TI-nspire with the 84+SE keypad, and the last time I changed the batteries was a LONG time ago, but the battery meter is full. I'm not sure it it's a problem with doors CS or if my batteries just last a really long time.
I recently began to organize my giant collection of Files/Programs. i did this by changing things like locking some, hiding others, and deleting the rest. after i deleted about 6 useless programs, my calculator crashed. I turned it back on and started organizing again. I delete more things and during somewhere around the 10th delete, my calculator crashed again. I don't know if it specifically has to do with deletes because i did other work between deleting but it only crashed on a delete.
Doors CS 7.2
TI-84 plus
OS 2.43
Doors CS 7.2
TI-84 plus
OS 2.43
Which error? Can you tell to where your code gets before the error triggers? Which version of Doors CS are you using?The error was happening on line #7, as it should.
I'm running DCS 7.2
https://ivoah.net
» Goto page Previous 1, 2, 3 ... 37, 38, 39, 40 Next
Page 38 of 40
