Just a place to kind of pool some notes and such.
I've been weighing the decision to base the game on the homescreen instead of the graphscreen because if I were to do it on the graphscreen like on the 83+ line, it would take you forever to get across one map.
Beyond that, everything else should be pretty much a straight port, as the coding syntaxes seemingly vary very little.
Well, we could teach you C, and you could make it fast, amazing, and complete it pretty quickly as a "graphscreen" type of game. Alternatively, you could do what Sarah is doing, and go for a Casio BASIC homescreen-type game, also fast and pretty nifty.
Well, I had initially started out thinking I could make it on the graphscreen. So the code doesn't go to waste, here is what I had to this point:
ClrGraph
0->Xmin
0->Ymin
216->Xmax
384->Ymax
Horizontal 0
Horizontal Ymax
Vertical 0
Vertical Xmax
1->W
225->A
25->B
While W=1
Text B,A,"A"
Getkey->K
If K
Then
Text B,A," " // 2 spaces
If End
IF K=47
Then
0->W
IfEnd
A-10((K=38 and A>5)-(K=27 and A<360->A
B-10((K=28 and B>5)-(K=37 and B<175->B
WhileEnd
Hopefully this doesn't bore anyone too badly :p I'll still give this some thought, might make use of it, or not. Would have to adjust how many pixels at a time a user would 'walk'.
Edit:
I'd also like to note that the code above isn't too horridly slow, either. I think it'd still be playable the speed that it displays. It takes longer to run the Vertical and Horizontal commands than it does to move the character around the screen.
An homescreen PRIZM remake would definitively be good, since it's the only fast thing in PRIZM BASIC and not only you can use colors for individual characters, but you also have access to some rather interesting characters.
Yeah, though I think I'll just leave it with the black border using characters, and simplify things. That was the beauty of that old game, it was simple, yet fun
Also, how does one initiate lists in Prizm BASIC? I've went and forgot how to do so
I'm afraid I don't remember how to do this, but exploring the Prizm wiki shows this example that should help.
Thanks for the info, I've found more information, posted it to a more appropriate thread. I've worked out the first batch of 'screens' for the map, now I need to move some code around so it sits in the proper spots of programs where it needs to be. (Copy and Paste make things SO nice on the Prizm)
Once I get it to clear the X's out of the sides that are passable, I'll make the actual game engine work. From there, it will be all about the battles.
Edit
I was able to confirm my idea will work in terms of opening the sides of the screen for borders. I'll probably go ahead and dump the rest of the screen data into that particular program and properly set it up to display the symbols for the various world objects.
I wish we had a good way of screenshotting things, looks like I'll be forced to take video with my camera when I want to show off my work. :/
As of right now, I've completed the inputting of all map data, pending any typos on my part, that should be done. It now properly generates the boundaries of the map and even is set up for segment bouncing. Oh yeah, and it's ready for me to add map interactions with items on the map Yay me!
Yes, I know the fan is loud, sorry about that, not much I can do.
Otherwise, what do you think thus far?
Edit:
Got the shifting between segments completed. On to the map interactions!
Work progresses with the Village program. Inn and Tavern completed, working on armory now, which should only leave me the shop, which also shouldn't be too hard to get implemented and ready to function.
Edit:
We now have a fully working Village system in place, with Armory, Inn, and Shop all ready and waiting.
Next up on the list is making the menu system work, to access stats, save, etc.
Since this has all been done on the home screen so far, I'm not 100% sure how I wish to proceed with this, but I'm sure I'll come up with something!
Way too little activity on this topic, I think its really nice although I'm not sure what
"ARE YOU HERE TO SAVE US?
HAHAHAHAHA!
THAT WAS REALLY FUNNY!"
Means
I did notice it says Welcome to Our... or welcome to My... maybe you could show who is saying that or change it
Anyway, amazing work
Well, it should be fairly obvious who is saying what. The towns folk, and the respective shop keepers, hence the our and my differences.
And the place you the player start at, you're known and not considered someone of importance.
Hello my dear friend I see your future add-in for our Lovely Casio PRIZM and It's really awesome
Please can you help glb08ma to improve Eigenmath Add-in. It's a kind of CAS for the PRIZM! Please we need you, you are a Guru, the Prizm needs you, he's asking for a Good CAS like Classpad 2 & HP Prime !
Sadly, he's programming in a language I know nothing about, so I'd be of no help to him right now. Most of my programming on the calculators have all been in BASIC.
Getting ready to work on this for a little bit, realized it might be good to post how large the game is in its current form, give me a marker of sorts on the size of the programs as I get closer to the final version of things.
In-game menu is 100% completed and fully integrated into the actual gaming engine. Next on the list is to finish up the events, followed by the battle engine.
In theory, the battle system is now set up to let players attack the enemy, they just cannot return attacks as of yet. Plus, the exp gain isn't programmed in, either.
Closing in on a beta release of the game, hopefully by the weekend. Hopefully the battle system has no errors in it, it's already over 2900 bytes in size, and I have a lot to add to it yet.
And I still need to update the gaming engine to use the enemy encounter and exiting from the battles properly.
