Is there any good documentation on how to program the HP Prime in general? I cannot seem to find a comprehensive guide of sorts.
Additionally, when trying to make a program that finds perfect numbers, I ran into a problem:
This code returns a "Bad Argument" error
EXPORT PERFECT()
BEGIN
FOR C FROM 1 TO 9999 DO
IF πLIST(CAS.ifactors(C))==C THEN
PRINT(C);
END;
END;
END;
in line 4, when performed in CAS or home view, a list is returned with "[]" brackets, yet does not return an error, and when {} brackets are used in the program (while not serving the purpose of the program), no error occurs.
Why is this, and how can I fix it?
Edit:
Thank you Kerm for telling me how to use BBCode for posting code segments!
*bump* Do any of our HP Prime users/programmers have some feedback on this? I'm afraid that I've encountered a similar barrier to entry with the language, and thus don't know the answer to jetlego's question.
I found http://www.hpmuseum.org/forum/thread-216.html that I printed off and was able to use the messagebox sample successfully. I haven't had a chance as of yet to progress through more of the tutorial.
Excellent list of up-to-date HP Prime documentation/programming can be found here: http://www.hpmuseum.org/forum/thread-818.html
Thank you for sharing that work with us. Don't forget to let them know that we have HP Prime Program Archives here.
