That's going to be interesting, good luck with it. Let me know when you finish so I can play with Celtic 2 CSE and rendering pieces.
Haha will do! Going to try to make those fixes sometime today. Need to look up how scoring is done so I can start implementing that as well.
My very clear and not at all long comment in Tetric A for scoring goes like this: Code:
;score += 2*(1+lastlines)*(y-firstclearedy)*(y-firstclearedy)*(level);
score = score + 2*(level)*(1+number_of_lines_cleared_last_piece)*(number_of_lines_cleared_this_piece)^2
Edit: But every time you drop a piece, lines_cleared_this_piece -> lines_cleared_last_piece, so if you clear a line, drop a piece that doesn't clear a line, and drop a third piece that clears a line, you get no bonus.
I guess I hadn't realized that the scoring was that 'complex'. I was going to go with something simple, mainly you get 2 points per piece that hits the bottom or otherwise stops, and X amount of points per line cleared, with the more lines cleared being awarded bonus. Hrm...
That would also work well, I'd think. It looks like the canonical game does something in between our two methods, complexity-wise: http://tetris.wikia.com/wiki/Scoring
I've managed partial blocking for pieces moving to the right into other pieces, and it seems to work fine going left, but when you get to the third row from the bottom, it allows the piece to go right one, even though it's registering there is a piece there.
This is the most up to date code so far.
:DCS
"0000005500000000000000550000000000000055000000000000005500000000000000550000000000000055000000000000005500000000000000550000000077777700000011007777770000001100774444000022111177444400002211116644440022223311664444002222331166666600223333336666660022333333
ClrDraw:AxesOff
2->W:1->D:5->C:1->V:2->T:1->U:0->P:1->theta
randInt(10,16->E
1+(E/|E2->E
0->Xmin:0->Ymin
264->Xmax:164->Ymax
Text(~1,1,91,"BTetris
Line(114,54,114,117,2,12
Line(148,54,148,117,2,12
Line(116,52,147,52,2,12
Line(116,119,147,119,2,12
{21,10->dim([A]
Fill(0,[A]
D->G
While W=2
getKey->K
If max(K={24,26,21,31:Then
Pt-Off((115+C*3)+L1(1),(115-(D)*3)-L1(2),1
Pt-Off((115+C*3)+L1(3),(115-(D)*3)-L1(4),1
Pt-Off((115+C*3)+L1(5),(115-(D)*3)-L1(6),1
Pt-Off((115+C*3)+L1(7),(115-(D)*3)-L1(8),1
If K=26:Then
If C+A<10 and ([A](D,C+A+1(C+A<10))=0 or [A](D+1,C+A+1(C+A<10))=0 or [A](D+2,C+A+1(C+A<10))=0 or [A](D+3,C+A+1(C+A<10))=0:Then
C+1->C
End:End
If K=24:Then
If C>1 and ([A](D,C-1)=0 or [A](D+1,C-1)=0 or [A](D+2,C-1)=0 or [A](D+3,C-1)=0:Then
C-1->C
End:End
If F!=C:C->F
V-(C+(A-1(A=2)+2(A=0)-2(A=3))<10)((K=31 and V>0)-(K=21 and V<5->V
If V=0:4->V
If V=5:1->V
If K=21 or K=31:1->theta
If K=105:Then
Text(150,110,"Paused
Pause
Text(150,110,"
If K=22:Then
DelVar [A]DelVar WDelVar L1DelVar |LADelVar |LBDelVar |LCDelVar |LD
ClrDraw:Disp :Return:End
If theta=1:Then
If |E2fPart(E)=10:Then
If V=1 or V=3:{3,0,6,0,0,3,3,3->L1
If V=2 or V=4:{0,0,0,3,3,3,3,6->L1
If |E2fPart(E)=11:Then
If V=1 or V=3:{0,0,3,0,3,3,6,3->L1
If V=2 or V=4:{3,0,3,3,0,3,0,6->L1
If |E2fPart(E)=12:Then
If V=1:{3,0,0,3,3,3,6,3->L1
If V=2:{0,0,0,3,0,6,3,3->L1
If V=3:{0,0,3,0,6,0,3,3->L1
If V=4:{3,0,3,3,3,6,0,3->L1
If |E2fPart(E)=13:Then
If V>0 and V<5:{0,0,3,0,3,3,0,3->L1
If |E2fPart(E)=14:Then
If V=1 or V=3:{0,0,3,0,6,0,9,0->L1
If V=2 or V=4:{0,0,0,3,0,6,0,9->L1
If |E2fPart(E)=15:Then
If V=1:{0,0,0,3,3,3,6,3->L1
If V=2:{0,0,3,0,0,3,0,6->L1
If V=3:{0,0,3,0,6,0,6,3->L1
If V=4:{3,0,3,3,3,6,0,6->L1
If |E2fPart(E)=16:Then
If V=1:{0,3,3,3,6,3,6,0->L1
If V=2:{0,0,0,3,0,6,3,6->L1
If V=3:{0,0,3,0,6,0,0,3->L1
If V=4:{0,0,3,0,3,3,3,6->L1
|E2fPart(E->Z
If max(Z={10,11,12,15,16:Then
If V=1 or V=3:Then:2->A:1->B:End
If V=2 or V=4:Then:1->A:2->B:End:End
If Z=13:Then:1->A:1->B:End
If Z=14:Then
If V=1 or V=3:Then:3->A:0->B:End
If V=2 or V=4:Then:0->A:3->B:End
0->theta
If D=G:Then
Pt-On((115+C*3)+L1(1),(115-(D)*3)-L1(2),1,|E2fPart(E
Pt-On((115+C*3)+L1(3),(115-(D)*3)-L1(4),1,|E2fPart(E
Pt-On((115+C*3)+L1(5),(115-(D)*3)-L1(6),1,|E2fPart(E
Pt-On((115+C*3)+L1(7),(115-(D)*3)-L1(8),1,|E2fPart(E
If T>U:Then
If D+B=20 or iPart([A](D+(L1(2)/3)+1,C+(L1(1)/3)))=1 or iPart([A](D+(L1(4)/3)+1,C+(L1(3)/3)))=1 or iPart([A](D+(L1(6)/3)+1,C+(L1(5)/3)))=1 or iPart([A](D+(L1(8)/3)+1,C+(L1(7)/3)))=1:Then
E->[A](D+(L1(2)/3),C+(L1(1)/3
E->[A](D+(L1(4)/3),C+(L1(3)/3
E->[A](D+(L1(6)/3),C+(L1(5)/3
E->[A](D+(L1(8)/3),C+(L1(7)/3
For(Q,0,3
If D+Q<=21:Then
Matr>list([A]^^T,D+Q,|LA
If sum(iPart(|LA))=10:Then
Q->L
For(O,1,10
Pt-Off(115+O*3,(115-(D+Q)*3),1
0->[A](D+Q,O
End:End:End:End
If L<5:3->W
0->R
D+L->M
0->N
While W=3
Matr>list([A]^^T,M,|LA
If sum(|LA)>0:Then
For(O,1,10
Pt-Off(115+O*3,115-M*3,1
[A](M,O)->[A](M+N,O
0->[A](M,O
If [A](M+N,O)>0
Pt-On(115+O*3,(115-(M+N)*3),1,|E2fPart([A](M+N,O
If R<5 and sum(iPart(|LA))=0:N+1->N
If R>5 and (sum(iPart(|LA))=0 or M<3:2->W
M-1->M:R+1->R
0->D:5->C:1->V:1->P:1->theta
S+1->S
randInt(10,16->E
1+(E/|E2->E
D+1->D
If P=0 and D!=G:Then
Pt-Off((115+F*3)+L1(1),(115-(G)*3)-L1(2),1
Pt-Off((115+F*3)+L1(3),(115-(G)*3)-L1(4),1
Pt-Off((115+F*3)+L1(5),(115-(G)*3)-L1(6),1
Pt-Off((115+F*3)+L1(7),(115-(G)*3)-L1(8),1
D->G
If P=1:D->G
0->P:5->L
End:"W=2
Seems I might have gotten the problem solved. Now all that I need to do is show how many lines are cleared and the score, and it should be ready for a release
Edit:
Updated the file: http://tifreakware.net/tifreak8x/btetris/BTETRIS.8xp
Would be very grateful if someone could play around with this for a while and see how it plays? Thanks in advance!
Edit:
Bug report: Tried moving a square block left near the lower-left of the playfield, with C=1 and D=15, and got an Invalid Dimension error near the If K=24 line. Solution: Because TI-BASIC doesn't do short-circuiting, break up the conditional:
Edit: Same thing seems to happen if you are holding the left arrow key when the piece hits the bottom.
If C>1:Then
If not([A](D,C-1)) or [A](D+1,...
tifreak8x wrote:
Alright, thanks. Were you having any issues going towards the right, or through pieces?
Pressing the right arrow against the right edge of the field didn't cause any problems. Pressing left when a piece was falling next to another piece made the falling piece get stuck inside the existing placed piece.
Bah, that shouldn't be happening. I'll do some more playing around with it, it wasn't doing that before hand. :< This is far harder than I thought it would be.
Any progress on tracking that bug down, tifreak8x? Or is it more of an issue of needing to redesign the rotate+move code? If the latter, you're more than welcome to pick at Tetric B for code or my brain for ideas and algorithmic details.
I've made some changes to the code, I just haven't tested it as of yet. I've updated the file at the link, and I'll try to test it later today. Yesterday was very busy in the shop. :<
I tested it some more, and it mostly seems to be fixed. I can't go through the left side and trigger a dimension error any more. The only time I can get a piece into another piece in a few minutes of testing is moving a piece left one place into another piece while it falls. Like so:
22
22 [ -> LEFT before during fall -> ] 22
11 122
11 11
111 111
*note to self*
Ignore row D is on, look at D+1 through D+4.
Updated the program at the link!
Just need to add scoring, level tracking, Line clearing(?), and game over detection.
- tifreak8x
- Guru (Posts: 11009)
- 30 Oct 2013 07:03:42 pm
- Last edited by tifreak8x on 30 Oct 2013 07:07:43 pm; edited 1 time in total
I think I've worked out the bugs for moving left and right with a new system that is more dynamic then what the previous setup allowed.
Also, here:
Thoughts?
For anyone to test it out
Also, here:
Thoughts?
Congratulations! I'm glad to hear you worked out the movement bugs. Is there anything left to do other than the lines/score/level numbers and tracking the score before I start poking at hybridization?
The only thing I've not added beyond those is detecting a game over.
And link edited in the post above
I got it 'finished'!
http://www.cemetech.net/programs/index.php?mode=file&id=969
Page 3 of 5
