Ok I will give you the full rundown of everything that is happening. I have a TI 84+BE with a USB cable that came in the box with it. TI-Connect worked fine for about 1 year for me and then problems started occuring.
When I want to send a program with TI-Connect it will recognize the calculator and start sending but then I will get a '8C010000' error or a '8007005' error code. But when I want to send a program and an Application, if I send the application first with the program following then it will transfer both. So I have conquered that problem and now all I have to do is send an app with it.
The other problem is when I try to upload files from my calc to my computer with TI-Explorer. It recognizes the calc and everything and then it will start uploading and then bam I get another '8C010000' error code. Now I tried uploading an Application and guess what it worked. Next I tried uploading an application and a program with the application going first, but I cannot do that. So I am stuck with only uploading applications to my computer.
Can someone please help me erase this error once and for all because it really is beginning to annoy me!
