- The Big HP Prime Bug List
- 20 Sep 2013 08:33:58 pm
- Last edited by iconmaster on 21 Sep 2013 09:30:37 am; edited 4 times in total
Ah, with every new calculator comes new bugs! I just got my HP Prime in the mail, and I've been playing with it. I've found some issues, so I'm posting a big list here. Just like this thread, I think it's a good idea to compile a nice big list to send. Of course, these 'bugs' might just be because I don't understand how things are supposed to work, but we'll remove those from the list when I figure it out. Please help by submitting bugs of your own! So, here goes:
Severe
• The HP data-link program crashes sometimes when you double-click on an application.
• Modifying certain variables in the data-link program while the calculator is using them can cause the calculator to crash.
• The Edit Integer dialog box, when in Edit mode, does not behave as expected. Works fine in the emulator.
• It’s not possible to input negative slope parameters in the Test function of the Explorer apps, even if the function expects you to input one to solve it.
• Entering in the Home or CAS screens a ? followed by any data causes the calculator to crash.
Moderate
• The table() function does not seem to function despite being in the catalog.
• In Geometry, labels from Numeric View seen in Plot View with a dark background enabled becomes unreadable.
• The Edit Integer dialog box experiences severe graphical issues when dragged.
• In some cases, the Info pane of applications in the data-link program displays garbage end characters if the calculator edited it before the application.
• The Help files for the MOUSE() function specify a mode type of #5 for detecting long-clicks, but a long-click never triggers with the function.
• The PIXON and PIXOFF commands, without optional arguments, both set the screen to white.
Trivial
• There’s no Help text for the following:
o left()
o right()
• There’s a Help article for the DataStreamer app, but it doesn’t appear when pressing the Help button in the app itself.
• The Settings for the Spreadsheet are accessed from the Symbolic View, but the only actually usable view is the Numeric view.
• There's a lot of mention of DOM_STRING, DOM_FLOAT, and the like in the Help files...
Severe
Moderate
Trivial
o left()
o right()
