I've just installed this Shell for my TI-84 Plus SE and I'm just amazed with it, because now I can organize my programs into separate folders. But, as I've already got tons of TI-BASIC programs in my calculator and I would like to separate them by categories (and I'm anxious to finish this chore), It looks like that the only way to do this is to cut each program, open a folder, paste it there and go back again. I wonder if there could be a way of selecting multiple files at once and just move them into a new folder.
Also, I would like to make another suggestion: It would be quite nice if I could select a command from the right-click menu using the 0-9 numbers from my keypad.
Nope. You can't select multiple files and then move or delete them all at once. You could certainly write such a program, though. Somebody besides me should totally do that.
You should even be able to write a Shell Extension to add the functionality directly to the shell.
Considering that you have a whole chunk of code that started towards this goal, I would think that someone besides someone besides you would be the perfect person.
Tito, welcome to Cemetech; I'm glad you like Doors CS! I also like the command selection idea, but have you tried out the TabFuncs SE to see if that does what you want? I believe that this version should work.
