I created Simon the memory game for prizm using pSDL to show the basics of what it can currently do(I'm working on image loading and I may be able to finish before I leave tomorrow).
At the first menu heres what you can do
Press 1 to start it with text at the bottom for which arrow it maps to
press AC/ON to start without the help
press esc to exit
while it is running it will who each color/help if you enabled it for 3/4 of a second and then once all are shown it will go to black and you can start inputing arrows and the screen will change to the appropriate color
if you manage to get to 25 correct you win(the game)
My code is not exactly the best example of SDL code but here it is...
I cant figure out how to attach so here is the link to the omni attachment http://www.omnimaga.org/index.php?action=dlattach;topic=13899.0;attach=13107
EDIT: fixed error where esc could lock up calc
press esc to exit
#include <SDL.h>
#include <fxcg_syscalls.h>
#include <fxcg/display.h>
#include <stdlib.h>
#include <string.h>
static unsigned long next = 1;
/* RAND_MAX assumed to be 32767 */
int sys_rand(void) {
next = next * 1103515245 + 12345;
return((unsigned)(next/65536) % 32768);
void sys_srand(unsigned seed) {
next = seed;
int main()
SDL_Surface *screen;
int i, j, k, width, height, bpp, done=0, printCase=0, win=1;
SDL_Event event;
SDL_Init(SDL_INIT_VIDEO|SDL_INIT_TIMER);
width = 384;
height = 216;
bpp = 8;
SDL_Color palette[5];
palette[0].r=255; palette[1].g=0; palette[1].r=0;
palette[1].r=0; palette[2].g=255; palette[2].b=0;
palette[2].r=0; palette[3].g=0; palette[3].b=255;
palette[3].r=255; palette[0].g=255; palette[0].b=255;
palette[4].r=0; palette[4].g=0; palette[4].b=0;
screen = SDL_SetVideoMode(width, height, bpp, SDL_SWSURFACE);
SDL_SetColors(screen, palette, 0, 4);
if (screen == NULL) return -1;
SDL_FillRect(screen, NULL, SDL_MapRGB(screen->format, 0, 0, 0));
SDL_UpdateRect(screen, 0, 0, 0, 0);
PrintXY(1, 1, "XXPress AC/ON to start", 0x20, TEXT_COLOR_WHITE);
PrintXY(1, 2, "XXPress Esc to Exit", 0x20, TEXT_COLOR_WHITE);
PrintXY(1, 3, "XXPress 1 for help", 0x20, TEXT_COLOR_WHITE);
Bdisp_PutDisp_DD();
while (!done)
while(SDL_PollEvent(&event)) {
if (event.type == SDL_KEYDOWN)
switch (event.key.keysym.sym)
case SDLK_ESCAPE:
return 0;
case SDLK_POWER:
done = 1;
break;
case SDLK_1:
printCase = 1;
done = 1;
break;
default:
break;
if (SDL_GetTicks() > 10000) return 0;
SDL_FillRect(screen, NULL, SDL_MapRGB(screen->format, 255, 255, 255));
unsigned char set[25];
unsigned char choice[25];
sys_srand(SDL_GetTicks());
for ( i=0; i<25; i++)
set[i] = sys_rand() % 4;
for (i=0; i<25; i++)
for (j=0; j<i; j++)
memset(screen->pixels, set[j], width*height);
if (set[j] > 3)
return -1;
if (printCase)
switch (set[j])
case 0:
PrintXY(18, 7, "XXUP", 0, TEXT_COLOR_BLACK);
break;
case 1:
PrintXY(16, 7, "XXRIGHT", 0, TEXT_COLOR_BLACK);
break;
case 2:
PrintXY(16, 7, "XXDOWN", 0, TEXT_COLOR_BLACK);
break;
case 3:
PrintXY(16, 7, "XXLEFT", 0, TEXT_COLOR_BLACK);
break;
Bdisp_PutDisp_DD();
SDL_Delay(750);
SDL_FillRect(screen, NULL, SDL_MapRGB(screen->format, 0,0,0));
SDL_UpdateRect(screen, 0,0,0,0);
k=0;
while (k<i)
case SDLK_UP:
choice[k]=0;
memset(screen->pixels, 0, width*height);
k+=1;
break;
case SDLK_RIGHT:
choice[k]=1;
memset(screen->pixels, 1, width*height);
k+=1;
break;
case SDLK_DOWN:
choice[k]=2;
memset(screen->pixels, 2, width*height);
k+=1;
break;
case SDLK_LEFT:
choice[k]=3;
memset(screen->pixels, 3, width*height);
k+=1;
break;
case SDLK_ESCAPE:
win=0;
i=100;
k=105;
break;
default:
break;
for (j=0; j<i; j++)
if (set[j] != choice[j])
win=0;
i=100;
if (win == 0) PrintXY(1, 1, "XXSorry You have lost", 0x20, TEXT_COLOR_WHITE);
else PrintXY(1, 1, "XXYou have won the game!", 0x20, TEXT_COLOR_WHITE);
Bdisp_PutDisp_DD();
SDL_Delay(2000);
return 0;
