When in the homescreen after exiting DCS, had anyone else not been able to use [2nd][ON] to turn off the calculator? If so, have you found a solution easier than going into DCS and turning it off from there?
souvik1997 wrote:
I haven't ever run into that before. Have you tried clearing your RAM and restarting DCS?
I also have never run into this particular problem at all. Are you running any other apps with hooks that might be interfering?
If you use omnicalc and the calc ever crashes while both omni and dcs are running there can be problems. I can help fix them if that is the case.
Edit by Kerm: "are" and "you" take milliseconds longer to type than "r" and "u". Please use proper grammar.
I have also ran into this problem, but more worse: I got all menus except the prog menu screwed up. What I did was creating an asm program with some random hex in it then running it.
That's not really the same problem at all, then. aeTIos wrote:
Hmm, afaik this issue came up when I used this program to run APPs from DCS.
I'm glad to hear that, because Doors CS can't run Apps.
IIRC, you wrote this program. Lemme look it up in the archives.
[edit]
found it:
http://www.cemetech.net/programs/index.php?mode=file&id=195
(It's for DCS6 but I don't know whether or not that has caused the calculator to act weirdly)
[edit]
found it:
Nope, that was C_plus_plus's program, as you discovered. I'm afraid that without his source code, I can't easilycheck if the program is properly-written.
You can decompile it pretty easy as far I know. Only problem is that in that case you don't have comments and label names.
