You can use a syscall to detect calc model and block app for cg10
That's true, although any programmer with the source code and two neurons to rub together would be able to reverse that. Out of curiosity, which syscall would do this?
Syscall 0x1196, or you can read the byte at 0xA0000305. The former is better; it returns 0x5A for an fxCG-10, 0xAA for an fxCG-20, and apparently it returns 0x00 on the emulator (reading the byte directly from memory on the emulator yields the model the emulator is emulating, or on hardware the same results as the syscall).
Is this documented on WikiPrizm somewhere? Purobaz was just looking for this information and had to search around for it for a while.
