clovervidia wrote:
It appears to only be 1kb, thought that might be the smallest unit Windows shows.
Never mind, on second thought, it is actually 76 bytes.
That's about the size of a file with no contents. Are you sure you compiled correctly? Don't forget, for mysong.asm or mysong.z80, the command is "compile mysong", NOT "compile mysong.asm" or "compile mysong.z80".
For some reason, the file was empty. -_-
I went back to the converter and tried again, and now it compiles.
It comes out to about 3kb, is that good?
Yeah, that should be a decent-sized if slightly short song. How does it sound?
To put it lightly, it sounds like R2D2 got run over by a garbage truck. Guess some fine tuning needs to be done, but at least it compiles now.
