bspymaster wrote:
Makes sense. You should probably explain that though. In the file it sounds like you need all three.
Would you mind pointing out the offending confusing paragraph for me so I can correct it?
calcman wrote:
By the way Sorunome in your signature you have spelled "enough" wrong is that a mistake on purpose?
No, thanks, that was just coz I'm german and so I'm not that good at spelling.... And Kerm, your profile isn't linked to your ticalc profile. Smile
Sure, Kerm. Sorry Smile.
Its on the DCS wiki under radio buttons.
http://dcs.cemetech.net/index.php?title=BasicLibs:PushGUIStack
Go to the label titled "GUIRRadio"
Fixed the wiki about the radio buttons. Smile
Wait, I think you're confusing a Group Master (ie, GUIRNull, GUIRSmallWindow, or GUIRLargeWindow, which each start a group on the GUI Stack that then can contain text, buttons, and all the other different types of the GUI elements) and the group ID for radio buttons, which defines which radio buttons get unselected when one gets selected.
Then... Can you explain how the radio button programming works? because the string command doesn't work, and I don't quite understand how to use it... Confused
Page 4 of 4
