so:
:xlib code
:storepicN
:sum(7,0,255/254
:sum(7,3,N
:sum(12,x,y,1
calcman wrote:
so:
:xlib code
:storepicN
:sum(7,0,255/254
:sum(7,3,N
:sum(12,x,y,1
255/254 means 255 or 254, not literally 255/254.
i know
255=clr graph buffer
254= copy unto graph buffer
calcman wrote:
i know
Correct, that's is what it is.
calcman wrote:
aint i always right?
Not always (see your post in your ASM) topic. Can I also impose on you to perhaps write longer posts that use correct grammar, punctuation, and capitalization? It will make your posts much easier and more pleasant to read.
Not always (see your post in your ASM) topic. Can I also impose on you to perhaps write longer posts that use correct grammar, punctuation, and capitalization? It will make your posts much easier and more pleasant to read. I am too lazy to actually make my own post so instead I quote people and then don't say anything new
Sorry, I am starting to post with correct, full sentences. I know it is annoying when I post short stuff like above.
Yes, much better! Keep up the excellent work and the excellent questions.
Well as the topic of this thread contains, 3rd party libs, I will ask this question here.
For Celtic, the det(17 is for converting hexidecimal to binary code, which is handy. But when you convert it, it changes into something unreadable,
example:
:clrhome
:input "Hex:",string1 ;not needed but need to store to something
:det(17,ans
:disp "Bin:",ans
:pause
:clrhome
During disp,ans
ans is converted into something random ex:
.DK
Is there something I am doing wrong?
It's converted to binary, but you can't read it as 1s and 0s since it is read by the TI OS as a token. If you want to read it as 1s and 0s, create your own base conversion program.
Okay, I will try to make something of that sort.
