Well now, some friends and I need a private place to test out mods and maps we make quickly and easily. So, I thought I'd put my linux-based website server to good use. Is it possible to host a dedicated server on a website? I have access cPanel, FTP, SQL, and the works.
qazz42 wrote:
Why not just get a VPS server?
Money. I have a server that works, and I don't have any money to spare. Plus, my ISP blocks some of the ports to host a game here.
You can't host UT2004 on shared hosting, heck you'd need a rather beffy VPS to do it.
"Have a nice day, or not, the choice is yours." Tom Steiner
Why not host a game or run a Dedicated Server from UT2004 then start UT2004 and join.
Another option could be a Listen Server, where your session in the game, when you leave it quits. Dedicated will run in the background, two instances of UT running at the same time.
ISP blocks a necessary port.
I'd bet it just your router and not your ISP.
Already thought of that, I opened the ports, it denies connection. I already talked to them, and they block Port 42292.
Then your stuck, there is no way a shared host will let you use it to host a game server.
Thanks for the help anyways.
There are many companies that will let you host a gameserver by the slots you want on it. 8 slot UT 2004 servers were as low as 7 USD a month last I saw. Which was a few months ago
- KermMartian
- Site Admin (Posts: 64059)
- Re: Hosting a UT2004 Server on a Website
- 09 Mar 2011 10:03:50 pm
I was going to suggest that you use the Cemetech UT server, but if you're testing mods, that'll work less well. s people said, a webserver isn't the right solution.
If I knew what you guys budget was I might could talk to some of my friends in the hosting business into giving you a fairly hefty VPS for about 35 a month.
That sounds like a lot of money compared with webserving, but that's actually a decent deal for VPSes, depending on what the specs are like.
2.8Ghz dedicated CPU share
4GB dedicated RAM
6.5GB Burstable
2TB Bandwidth @ 100Mb/s
No control Panel (gotta get your own cPanel if you want it)
root access (obviously)
