Im making a game called Choice Endurance (CE for short) and im trying to get it to add 500 health after every battle. I have something set up, but it just resets the 2nd battles health to 500 instead of 538 or something. Heres the code......
First battle:
:ClrHome
:AxesOff
:ZStandard
:ClrDraw
:Text(25,35,"LOADING")
:Shade({-}3,{-}1
:ClrHome
:ClrDraw
:1000→A:1000→B
:DelVar CDelVar DWhile A>0 and B>0
:Text(1,1,Str2+":",A)
:Text(16,1,"BRIGGS:",B)
:Text(32,1,"HIT WHERE?")
:Text(40,1,"LOW=1 MID=2 HI=3")
:DelVar Z:Repeat Z=92 or Z=93 or Z=94
:randInt(1,3→D
:getKey→Z
:End
:ClrDraw
:If Z=92 and D=1
:Text(48,1,"BLOCKED")
:If Z=92 and D=2
:Then
:randInt(1,20→E
:A-E→A
:Text(48,1,"BRIGGS HITS")
:End
:If Z=92 and D=3
:Then
:randInt(1,20→E
:B-E→B
:Text(48,1,Str2+" HITS")
:End
:If Z=93 and D=1
:Then
:randInt(1,15→E
:B-E→B
:End
:If Z=93 and D=2
:If Z=93 and D=3
:Then
:randInt(1,15→E
:A-E→A
:End
:If Z=94 and D=1
:Then
:randInt(1,10→E
:A-E→A
:End
:If Z=94 and D=2
:Then
:randInt(1,10→E
:B-E→B
:End
:If Z=94 and D=3
:End
:ClrHome
:If A≤0 and B≥0
:Then
:"BRIGGS WINS        GAME OVER
:prgmA
:ClrDraw
:AxesOn:Goto A
:End
:If B≤0 and A≥0
:Then
:"YOU WIN   CONGRATS!
:prgmA
:ClrDraw
:AxesOn
:End
Secibd Battle:
:ClrHome
:AxesOff
:ZStandard
:Shade({-}3,{-}1
:ClrHome
:ClrDraw
:A+500→A:1000→B
:Text(16,1,"TANK:",B)
:randInt(1,3→D
:getKey→Z
:End
:ClrDraw
:If Z=92 and D=1
:If Z=92 and D=2
:Then
:randInt(1,20→E
:A-E→A
:Text(48,1,"TANK HITS")
:End
:If Z=92 and D=3
:Then
:randInt(1,20→E
:B-E→B
:End
:If Z=93 and D=1
:Then
:randInt(1,15→E
:B-E→B
:End
:If Z=93 and D=2
:If Z=93 and D=3
:Then
:randInt(1,15→E
:A-E→A
:End
:If Z=94 and D=1
:Then
:randInt(1,10→E
:A-E→A
:End
:If Z=94 and D=2
:Then
:randInt(1,10→E
:B-E→B
:End
:If Z=94 and D=3
:End
:If A≤0 and B≥0
:Then
:"TANK WINS          GAME OVER
:prgmA
:ClrDraw
:AxesOn:Goto A
:End
:If B≤0 and A≥0
:Then
:"YOU WIN   CONGRATS!
:prgmA
:ClrDraw
:AxesOn
:End
:Goto θθ
:Lbl H
:ClrHome
:AxesOff
:ZStandard
:Shade({-}3,{-}1
:ClrHome
:ClrDraw
:1000→A:1000→B
:Text(16,1,"SPIDER:",B)
:randInt(1,3→D
:getKey→Z
:End
:ClrDraw
:If Z=92 and D=1
:If Z=92 and D=2
:Then
:randInt(1,20→E
:A-E→A
:Text(48,1,"SPIDER HITS")
:End
:If Z=92 and D=3
:Then
:randInt(1,20→E
:B-E→B
:End
:If Z=93 and D=1
:Then
:randInt(1,15→E
:B-E→B
:End
:If Z=93 and D=2
:If Z=93 and D=3
:Then
:randInt(1,15→E
:A-E→A
:End
:If Z=94 and D=1
:Then
:randInt(1,10→E
:A-E→A
:End
:If Z=94 and D=2
:Then
:randInt(1,10→E
:B-E→B
:End
:If Z=94 and D=3
:End
:If A≤0 and B≥0
:Then
:"SPIDER WINS        GAME OVER
:prgmA
:ClrDraw
:AxesOn:Goto A
:End
:If B≤0 and A≥0
:Then
:"YOU WIN   CONGRATS!
:prgmA
:ClrDraw
:End
What should i do?
Are you deleting variable A somewhere between running the two programs? does prgmA touch variable A?
I don't know whether it does or not.
Post the code of prgmA here so we can see.
Heres prgmA:
:Ans+" →Str1
:DelVar A1→B
:ClrHome
:While Ans
:inString(Str1," ",A+1→C
:If 16<Ans-B or not(Ans
:Then
:Disp sub(Str1,B,A-B
:A+1→B
:End
:C→A
:End
:Pause
:ClrHome
This code changes B in the line A+1->B, so you'll have to back up B somewhere before running the program.
backup B?
adamac15 wrote:
backup B?
Store B to a temporary variable. What is prgmA used for?
prgmA is a wordwrap program
Did you make sure it doesn't touch variable A?
i know nothing about that. do you think if i removed prgmA, it would work?
It apparently deletes variable A. ๐Ÿ˜‰
then what do i do?
Where did you get the word wrap program, or did you program it yourself? I think the problem is in that program. ๐Ÿ™‚
I got it from someone who addressed me to it. (although i forget who.)
I made the word wrap routine. If it uses a variable that another program needs, then by all means, use a variable that the other program doesn't use.
So did you check if it uses A or not?
it does but i need batteries for my calc again. Ill have to wait till i get some more for it to fix it. Stupid cheap batteries.
Ah, good luck then; let us know once you've taken a look at prgmA. Perhaps it's in a thread here somewhere?
http://www.cemetech.net/forum/viewtopic.php?t=5165&start=0
here it is...youll have to go down the page a bit.
Page 1 of 2
