- How To Write an OS
- 09 Sep 2010 06:27:27 pm
- Last edited by SirCmpwn on 07 Oct 2011 10:36:52 am; edited 2 times in total
EDIT: If you are interested in making your own OS, I strongly suggest using AsmOS as a starting point, which includes everything discussed in this tutorial.
Hello!
Several people may want to write their own OSes, but I know from experience that it is very hard finding out where to start. I have put together a small tutorial and a basic kernel so that anyone who wants to can get started building their own OSes.
If anyone wants to skip the struggle of simply getting something to boot, I have attached KnightKernelBasic, which is what I gave to Eeems to build Rouge on. It requires ZDS, and I recommend using TI Developer with it as well.
Every OS needs these, just to boot:
*Page 00
*A valid OS header
But if you want it to actually do anything useful, it needs to:
*Initialize the LCD
*Set up memory
*Initialize the stack
You should have some other stuff, but that's all you really *need.* In order to boot and display something pretty, you really just need to have page 00, the stack, LCD, and a header. A basic OS header looks like this:
You could copy this into a document and start coding at Boot: and have an OS. This is also valid and signable, and may be sent to a calculator. It is worth noting that you need to have an interrupt or risk crashing the calculator. Add it at rst 38h:
This is a basic interrupt with blank spots to put your code. In order to actually compile and test your OS, you need to sign it. It may also be useful to convert it to a ROM for testing. TI Developer will do this for you automatically, but if you don't want to use ZDS or TI Developer, you can use os2tools.
Simple code to set up the LCD so you can draw on it:
And to set up memory (ROM 00\ROM 01\RAM 01\RAM 00):
Now go build some OSes!
Hello!
*Page 00
*A valid OS header
*Initialize the LCD
*Set up memory
jr Boot
db 0,0,0,0,0,0
db 0, 0 ; rst 08h
db 0,0,0,0,0
db 0, 0 ; rst 10h
db 0,0,0,0,0
db 0,0 ; rst 18h
db 0,0,0,0,0
db 0, 0 ; rst 20h
db 0,0,0,0,0
db 0,0 ; rst 28h
db 0,0,0,0,0
db 0,0 ; rst 30h
db 0,0,0,0,0,0,0
db 0, 0 ; rst 38h / System Interrupt
db 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
jp Boot
dw 0A55Ah
Boot:
; This executes at bootYou could copy this into a document and start coding at Boot: and have an OS. This is also valid and signable, and may be sent to a calculator. It is worth noting that you need to have an interrupt or risk crashing the calculator. Add it at rst 38h:
; System Interrupt Routines
SysInterrupt:
exx
ex af, af'
in a, (04h)
bit 0, a
jr nz, HandleON
bit 1, a
jr nz, HandleTimer1
bit 2, a
jr nz, HandleTimer2
bit 4, a
jr nz, HandleLink
jr InterruptDone
HandleON:
in a, (03h)
res 0, a
out (03h), a
set 0, a
out (03h), a
; ON interrupt
jr InterruptDone
HandleTimer1:
in a, (03h)
res 1, a
out (03h), a
set 1, a
out (03h), a
; Timer one interrupt (might be best to merge with timer 2)
jr InterruptDone
HandleTimer2:
in a, (03h)
res 2, a
out (03h), a
set 2, a
out (03h), a
; Timer two interrupt
jr InterruptDone
HandleLink:
in a, (03h)
res 4, a
out (03h), a
set 4, a
out (03h), a
; Link interrupt
InterruptDone:
ex af, af'
exx
ei
retThis is a basic interrupt with blank spots to put your code. In order to actually compile and test your OS, you need to sign it. It may also be useful to convert it to a ROM for testing. TI Developer will do this for you automatically, but if you don't want to use ZDS or TI Developer, you can use os2tools.
ld a, 40h
out (10h), a
ld a, 05h
call LCDDelay
out (10h), a
ld a, 01h
call LCDDelay
out (10h), a
ld a, 3
call LCDDelay
out (10h), a
ld a, 0F6h
call LCDDelay
out (10h), aAnd to set up memory (ROM 00\ROM 01\RAM 01\RAM 00):
ld a, 1 ; Set flash page 1 in bank 1.
out (6), a
in a, (2) ;get calc version
rlca ;Roll bit 7 into carry.
ld a, 41h ; Set ram page 1 in bank 2.
jr nc, LowerModel
HigherModel:
out (5),a
ld a,81h
out (7),a
jr Done
LowerModel:
out (6), a
out (7),a
Done:Now go build some OSes!
