I'm having a minor problem. When I enable the 'Launch DCS at startup' option, and I actually try to start my calculator afterwards, the 'on' button seems a bit unresponsive.
There are 3 things that can happen:
- Case 1: The calc starts and DCS is activated, everything normal.
- Case 2: It seems like nothing happens, but you can see that the screen was activated and then immediately de-activated, because of the slight flicker.
- Case 3: When I tried to hold down the 'on'-button to start it, the calc started, DCS was active. But when I released the 'on'-button, the screen cleared/the calc shut down.
This isn't -that- much of a problem since I can still turn it on within a second by clicking multiple times, but yeah, you asked me to post it q:
Things I did to exclude human failure:
- Tried other batteries
- De-activated the auto-launcher and tried the 'on'-button a few dozens of times, to make sure it's not just my 'on'-button having a defect.
Calculator specs:
TI-84 +, Basic Edition
Still running on 2.43 (I refused to try the new one since all the problems that I heard off)
Backcode: P-0308K
No clocking
It did get screwed a bit once when I was testing some of Calc84Maniacs projects. He then gave me a line of ASM that fixed my calc after execution, although, slower in some aspects. It might be just that.
Belgier
Calculator specs:
Backcode: P-0308K
No clocking
Belgier
