I also spelled the heightscript folder wrong.
When I try to load the map from my addon:
"You do not have the correct version of FreeBuild or the related art needed to connect to this server, please contact the server operator to obtain the latest version of this game (Invalid packet.)"
elfprince13 wrote:
That usually means you're missing artwork. Look in the console.
Ah yes, I remember that from the early days back when I was first creating BL-Sahara, my undersea map, and CemetechCities 1 and 2. elfprince13 wrote:
oh, I thought you were one of our mac fanboys. Why not just open console.log directly then?
I second this recommendation, although I would also like to know why the console didn't work for you.
We do have Macs but I only use them when I don't have enough time to boot up my computer.
Anyway console.log:
Edited by Kerm for length
Anyway console.log:
//-------------------------- 7/17/2010 -- 19:32:47 -----
Processor Init:
Intel (unknown, Pentium Pro/II/III family), ~2.40 Ghz
(timed at roughly 2.40 Ghz)
FPU detected
MMX detected
SSE detected
Math Init:
Installing Standard C extensions
Installing Assembly extensions
Installing FPU extensions
Installing MMX extensions
Installing SSE extensions
Input Init:
keyboard0 input device created.
mouse0 input device created.
DirectInput enabled.
[SNIP]
Logging in...
Executing core/client/scripts/client.cs.
core/client/scripts/client.cs (100): continue outside of loop... ignoring.
[SNIP]
--------- Initializing MODS ---------
Executing mods/client/init.cs.
Executing mods/client/ui/ModLoaderGui.gui.
Executing mods/client/scripts/ModLoaderGui.cs.
Executing mods/client/ui/AboutMod.gui.
Executing mods/client/scripts/aboutmod.cs.
Executing mods/TerrainFixer/init.cs.
Executing mods/TerrainFixer/main.cs.
Executing mods/StarWarsPack/init.cs.
Star Wars content pack activated
Executing mods/ExampleMod/init.cs.
Executing mods/ExampleMod/main.cs.
Executing mods/ExampleMod/client/main.cs.
Executing mods/ExampleMod/client/scripts/example.cs.
Executing mods/CastlePack/init.cs.
Castle/Fantasy content pack activated
exec: invalid script file mods/Australia/init.cs.
Searching for GameModes
Executing mods/CastlePack/server/scripts/dynload/gamemodes/CTC.cs.
Executing core/server/scripts/dynload/gamemodes/sandbox.cs.
Executing core/server/scripts/dynload/gamemodes/deathmatch.cs.
--Search Complete: 3 found
Engine initialized...
Initializing LDraw Subsystem...
Please point $pref::ResourceManager::LDrawDirectory at a valid LDraw installation
Exporting server prefs...
Executing core/server/scripts/accessors/gameConnection.cs.
Executing core/server/scripts/constants.cs.
Executing core/server/scripts/dynload.cs.
Executing core/server/scripts/audioProfiles.cs.
[SNIP]
Executing core/server/scripts/dynload/explosions/blackholeGunExplosion.xpld.
activeModPath() should NOT be pulling up blank %mod names
Could not load required datablock based on query: '*/server/scripts/dynload/audioprofiles/blackHoleBoomClose3d.audp'
Object 'blackHoleBoomClose3d' is not a member of the 'AudioProfile' data block class
Executing core/server/scripts/dynload/explosions/AcidGunExplosion.xpld.
mass loaded 34 explosions
[SNIP]
Executing core/server/scripts/iGobs.cs.
Executing core/server/scripts/serverauth.cs.
Executing core/server/scripts/CTF.cs.
Server MissionType Sandbox
*** LOADING MISSION: mods/Australia/data/missions/TBG-Australia.mis
*** Stage 1 load
*** Stage 2 load
Executing mods/Australia/data/missions/TBG-Australia.mis.
mods/Australia/data/missions/TBG-Australia.mis (0): Register object failed for object Terrain of class TerrainBlock.
*** Mission loaded
-----------CONN = 2956
Connect request from: IPX:00666F67:566F6C756D65:49
Connection established 2956
CADD: 2957 local
Blarg: 212
Lucas W
Anything?
11
Anything?
33
*** Sending mission load to client: mods/Australia/data/missions/TBG-Australia.mis
Mapping string: updatePrefs to index: 0
Mapping string: ServerMessage to index: 1
Mapping string: MsgConnectionError to index: 2
Mapping string: MsgLoadInfo to index: 3
Mapping string: MsgLoadimage to index: 4
Mapping string: clientVersion to index: 0
Mapping string: ghostcolor to index: 1
Mapping string: clientprofile to index: 2
Mapping string: iGobcolor to index: 3
Mapping string: editoroptions to index: 4
Mapping string: updatePrefs to index: 5
Set::getObject index out of range.
core/server/scripts/TBGserverCmd.cs (574): Unable to find object: '-1' attempting to call function 'getDataBlock'
core/server/scripts/TBGserverCmd.cs (575): Unable to find object: '-1' attempting to call function 'getDataBlock'
core/server/scripts/TBGserverCmd.cs (576): Unable to find object: '-1' attempting to call function 'getDataBlock'
core/server/scripts/TBGserverCmd.cs (577): Unable to find object: '-1' attempting to call function 'getDataBlock'
Anything?
22
Mapping string: MsgLoadDescription to index: 5
Mapping string: MsgLoadInfoDone to index: 6
Mapping string: clrFxData to index: 7
Mapping string: getFxData to index: 8
Mapping string: MsgClientJoin to index: 9
Hew:
2957
Mapping string: MissionStartPhase1 to index: 10
*** New Mission: mods/Australia/data/missions/TBG-Australia.mis
*** Phase 1: Download Datablocks & Targets
Mapping string: Lucas W to index: 11
Hew: 212 Lucas W
Lucas W
2957
Adding row for 2957
name Lucas W
tag Super
score 0
Mapping string: MissionStartPhase1Ack to index: 6
Validation required for shape: mods/castlepack/data/shapes/dragon/dragon.dts
Validation required for shape: core/data/shapes/bricks/vehicles/tbmcopter.dts
Validation required for shape: core/data/shapes/bricks/vehicles/sigmafighter2.dts
Warning: shape core/data/shapes/bricks/vehicles/sigmafighter2.dts collision detail 1 (Collision-1) bounds exceed that of shape.
Validation required for shape: core/data/shapes/bricks/vehicles/psiwing.dts
Warning: shape core/data/shapes/bricks/vehicles/kart.dts collision detail 1 (Collision-1) bounds exceed that of shape.
Validation required for shape: core/data/shapes/bricks/vehicles/dwing.dts
Warning: shape core/data/shapes/bricks/vehicles/dwing.dts collision detail 1 (Collision-1) bounds exceed that of shape.
Warning: shape core/data/shapes/bricks/vehicles/diesel.dts collision detail 1 (Collision-1) bounds exceed that of shape.
Validation required for shape: core/data/shapes/bricks/vehicles/blimp/blimp.dts
Warning: shape core/data/shapes/elfprince/portcullis9x13.dts collision detail 1 (Collision-1) bounds exceed that of shape.
Warning: shape core/data/shapes/elfprince/jail_door.dts collision detail 1 (Collision-1) bounds exceed that of shape.
Error: shape core/data/shapes/bricks/arch1x3x2curve.dts-collision detail 13 (Collision-2) bounds box invalid!
Warning: shape core/data/shapes/bricks/brick1x4x5window.dts collision detail 1 (Collision-1) bounds exceed that of shape.
Warning: shape core/data/shapes/bricks/rearwing.dts collision detail 1 (Collision-1) bounds exceed that of shape.
Mapping string: MissionStartPhase2 to index: 12
*** Phase 2: Download Ghost Objects
Mapping string: MissionStartPhase2Ack to index: 7
Could not locate texture: mods/data/water/water
Sending request for file mods/data/skies/Taehl/calm/calm2hack.dml
No such file 'mods/data/skies/Taehl/calm/calm2hack.dml'.
Connection error: Invalid packet..
Exporting client prefs
Exporting IP banlist
Exporting saved player prefs
Error, cannot unlink namespace parent linkage for firstruncontrolswindow for GuiButtonCtrl.
CDROP: 2957 IPX:00666F67:566F6C756D65:49
Uninitializing chunk mappings...
I took the liberty of trimming down your console.log to a more manageable size, removing nothing of import. Removals are marked with [SNIP].
KermM: As would I. I've seen the problem on occasion, but usually it works just fine.
Lucas: Several interesting things going on here.
Code that needs to be cleaned up.
Your init.cs appears to be invalid.
If you have LDraw on your computer, it is worth pointing the preference to the right place so you don't have to close out the dialog box every time you start the game.
We had to remove the blackholegun stuff a while back. Looks like the rest of the datablocks need to be cleared out.
Something is wrong with your TerrainBlock.
I need to un-oneliner this section of code to check for invalid accessorizing, but also smething is weird with your accessory preferences.
You're using ~/ paths aren't you? Tsk. Tsk. You need to specify the full path to the texture you want. Either in core/data/ or mods/Australia/data/ or in the data directory for a mod listed as one of your dependencies.
Lucas W wrote:
Lucas W wrote:
Lucas W wrote:
Lucas W wrote:
Lucas W wrote:
Lucas W wrote:
Lucas W wrote:
You told me to have init.cs blank.
I don't know whats wrong with my terrain block....... EDIT: The default path for the terrain is ~/ so that's why.
and I'll check about those paths.
EDIT 2: Well, I can spawn now. Only problem is that my display drivers and FB crashes.
Hmm, I should update the engine to just return quietly on a blank script file.
Page 3 of 4
