Jumper
  3. TI-84 Plus C Silver Edition Assembly Programs
  4. TI-84 Plus C Silver Edition Assembly Games
Jumper v1.0 - Send Jumper.8xp to the Flash/Archive section of your calculator using TI Connect and run it by selecting it from the DCSE menu. At the start of the game select your character by pressing left or right then press enter to start the game. The goal of the game is to collect as many points as you can by jumping up off of the platforms. Use the arrow keys to control character, press On to exit the game and press F1 to pause. The green platforms are normal, blue moves from side to side, brown will dissappear after you jump on it and you will not jump as high, black will make you jump higher, yellow will give you 1,000 extra points and you will jump a little higher, red will send you flying in a rocket, and pink moves from side to side quickly.
Screenshot #5209
Jumper.8xp 17.1 KB
notes.txt 1.2 KB
9.9 KB
10 years ago
9/10 (2 votes)
  1. Jumper (published 10 years ago; 2013-12-07 21:47 UTC)
