Frogger
  3. TI-84 Plus C Silver Edition Assembly Programs
  4. TI-84 Plus C Silver Edition Assembly Games
Frogger v1.4 is a flash app and ASM game for the TI-84 Plus C Silver Edition calculator. Send Frogger.8ck to your calculator using TI Connect and run it by selecting it from the Apps menu, or send Frogger.8xp and use Doors CSE 8 or higher to run it. Use the arrow keys to control the frog, press F1 to pause the game, and press ON to exit the app. Levels are randomly generated and you start with 3 lives. The object of the game is to land in each of the 5 water holes at the top of the screen. You get 500 points for landing in each hole. If a fly happens to be in the hole, you get an extra 200 points. If there is an alligator in the hole or if you land in the same hole twice, you die. If you get hit by a car or land in the water you die. If you land in all 5 holes, you move on to the next level. If you can beat the level in ~45 seconds, you can get up to 5,000 extra points.
Screenshot #5207
Frogger.8ck 38.6 KB
Frogger Notes.txt 1.7 KB
DCSE Icon/Frogger.8xp 576 bytes
13.3 KB
8.5/10 (2 votes)
  1. Frogger (published 11 years, 5 months ago; 2013-12-07 21:43 UTC)
