Buttonz
  3. TI-84 Plus C Silver Edition Assembly Programs
  4. TI-84 Plus C Silver Edition Assembly Games
Buttonz v1.8 is a flash app and ASM program for the TI-84 Plus C Silver Edition calculator. Send Buttonz.8ck to your calculator using TI Connect and run it by pressing [APPS] and selecting Buttonz. You can also sent Buttonz.8xp to your calculator and run it with Doors CSE 8 or higher. Match the blocks to the color of the arrows. The closer the block is to the center of the arrows the more points you will get. If its pretty close to the center, your bonus will go up and you will receive up to 5 times the points. Your bonus will decrement if the block is not centered. If there is no block present, your bonus will go straight to 1 and you will lose 10 points. If a block goes down through the bottom of the screen or if you match the wrong color, you lose a life. You have three lives to get as many points as you can. Use the left and right buttons to shift the color of the arrows. Press F1-F5 to select the blocks. Press the 2nd key to increase the level up to level 10. Pressing On at any time will exit the app.
Screenshot #5047
Buttonz.8ck 38.6 KB
Buttonz Notes.txt 2.2 KB
DCSE Icon/Buttonz.8xp 574 bytes
13.8 KB
7/10 (1 vote)
  1. Buttonz (published 11 years, 7 months ago; 2013-12-07 21:42 UTC)
