HASHLIB CE Cryptography Library
- TI-84 Plus CE Programs
- TI-84 Plus CE Assembly Math Programs
This is a LibLoad-compatible library that contains numerous cryptographic implementations. They are as follows: (1) SHA-1, (2) SHA-256, (3) Blowfish encryption, ECB mode, (4) Base64 encode/decode, and (5) A cryptographically-secure pseudo-number generator. It also contains a miscellaneous function to zero out a pointed context when you are done with it. I have plans to add the public key side of RSA (variable key lengths between 512 and 1024 bits), and perhaps even bcrypt if I can work out the bugs in it.
hashlib/makefile | 1.1 KB |
hashlib/hashlib.asm | 107.8 KB |
hashlib/Hashlib Documentation.pdf | 209.9 KB |
hashlib/hashlib.h | 9.9 KB |
hashlib/hashlib.lib | 587 bytes |
hashlib/hashlib.8xv | 22.0 KB |
- 243.2 KB
- http://ceme.tech/DL2123
- ACagliano
- 2 years, 11 months ago
- ↳ this version
- 121
- ↳ this version
- 899
- HASHLIB CE Cryptography Library (published 2 years, 3 months ago; 2022-02-05 00:02 UTC)
- HASHLIB CE Cryptography Library (published 2 years, 3 months ago; 2022-02-03 05:18 UTC)
- HASHLIB CE Cryptography Library (published 2 years, 6 months ago; 2021-10-29 14:12 UTC)
- HASHLIB CE Cryptography Library (published 2 years, 10 months ago; 2021-06-27 06:09 UTC)
- HASHLIB CE Cryptography Library (published 2 years, 11 months ago; 2021-05-28 21:44 UTC)
- HASHLIB CE Cryptography Library (published 3 years, 2 months ago; 2021-02-22 06:53 UTC)
